04-06 Ralliart Engine/Drivetrain (no forced induction)
Lazukard Engine built !
Old May 21, 2011 | 10:11 PM
Lazukard's Avatar
More Pics SOON !!! My built is finished, I give you some pics of the engine bay tomorow.
Old May 21, 2011 | 10:32 PM
Lazukard's Avatar
Just for information
The part on my built (Not everything on pics)
Custom Ported Head
Custom Ported OBX Header
Custom Ported 3.8L Throttle Bode (68mm)
SDK Ported Intake Manifold
A custom Porting fitting with Every Part For maximize the FLOW with the Header and the Head / Intake Manifold with the Head.
Custom Regrinding Camshaft
ARP Head Studs (Evo 8)
OBX 4G64 Ajustable Cam Gear
RPW Thermo Spacer Gasket Intake Manifold and Throttle Body
RPW FUel Rail
Toyota Supra 3GEGS 315CC Injector
Other Mods :
Megan Racing Evo 8 Radiator
Evo 8 Red Radiator Silicone Hose
Magnaflow RRM Catback 2.25
RRM Timing Box
RRM SS Clucht Line
RRM Underdrive Pulley
RRM PIggyBack PSC1
RRM Motor Mounts
AASCO Lightweight FLywheel
ACT Ceramic 6 Puds Clucth
Injen Cold Air
NRG Grounding Kit
D2 Racing Coilovers
DENSO 150 Amp Altenator
Nascar PRO serie Battery
Stoptech Ceramic Pad + Drilled ROtor
My next Project Is the TRansmission! (A Complet Brand new rebuilt with a QUalif LSD)
The 3rd gear is jammed
ANd Monday I go to a Dyno shop at Quebec (Turbo Expert) For test my Build and a complet reflashing of my ECU For Maximize the Gain with my New build (Ajuste the Cam Ytoo for find a good compromise in torque or in Power).
Old May 22, 2011 | 04:16 AM
ralliart610's Avatar
Nice build. Post up the dyno sheet afterwards. Video would be cool too. The only thing is i dont think you would need the timing box if your getting the reflash.
Old May 22, 2011 | 04:23 AM
lanzerralliart's Avatar
EvoM Super Moderator
Looks good and yet all so fimilar lol , keep it up and keep us posted....
Old May 22, 2011 | 05:47 AM
Ralliart_on_LSD's Avatar
very good. Good luck with the build, keep us posted the moment you get back from the tuning session.
Old May 22, 2011 | 06:55 PM
Lazukard's Avatar
Ready for the Road ! Very Crazy built for a NA
My new interior in Carbon! And the Oil pressure gauge is very cool ! When the Mivec Kick On the Oil Pressure Drop down quickly for change valve timing
My new Cf hood
My new Megan Racing Radiator Fit perfectly with the OEM Fan
Full coilovers suspension D2 Racing! Very Good Product and Great Quality but $$$
Brand New Denso 150 Amp Alternator
Toyota Supra big injector with RPW Fuel Rail
SDK Intake Manifold
RRM Motor Mount + RRM clucht line
ALL Interior Part Is in Carbon and The top Is painted in Black
More pic SOOn Enjoy! DYNO and Tuning monday!
Old May 22, 2011 | 07:01 PM
Lazukard's Avatar
My next step is Rebuilt the Transmission with the RRM LSD or Try to do The Same Diavlo AWD Conversion.
And If I am good in my budget I will try to put the Turbo during the summer
Old May 22, 2011 | 08:07 PM
CrAnSwIcK's Avatar
That my friend is clean. Would also be curious to see dyno or timeslip. pretty thorough N/A build though, post some pics of your "under-carriage" lol, (exhaust specifically), And is the clutch disc solid?
I have heard good things about a quality LSD, it should be very good for you, to me, the way you've done the rest of the car, AWD conversion should be a more long term goal if you have the time and money, i wouild enjoy it now. LSD does not take a lot of time if you are careful, and follow the procedure.
Old May 23, 2011 | 04:31 AM
Looks great it all looks so fresh good job man. I had to paint the interior pillars and roof black too it looks so much better in the car.
I know you said the radiator fit perfectly but was that in anyway an exaggeration? I've seen the misimoto one fit but it had minor problems with the fans bolting up. It was completely bolt on , no fab work? And the evo 8 hoses seem to have fit pretty well, the upper hose looks a little kinked on the motor side but was any cutting needed?
And as for the injectors, why only upgrade them by 10cc?
Old May 23, 2011 | 05:36 AM
dacib's Avatar
Looks amazing!
What kind of wires did you use for your grounding kit?
Old May 23, 2011 | 10:17 AM
gundum's Avatar
nice bro keep it clean
Old May 23, 2011 | 05:38 PM
Lazukard's Avatar
Originally Posted by dacib
Looks amazing!
The RRM Grounding kit
Old May 23, 2011 | 05:53 PM
Lazukard's Avatar
For the fan and radiator, check on the two pics
small fan
Big fan. The two fit bolt on radiator.
Trust me the RRM Megan Racing Radiator fit perfectly...
The Green Injector is the 2.4 OEM Injector +- 295cc
The brown is Toyota Supra 3GEGS Injector +- 315cc
The Brown have a better Core. Able to support more fuel Pressure. The Number of CC is not the only reference for Compare two Injector.
Dont Forget Without Turbo Too Bignest injector is useless and can make a too Rich Built
Old May 23, 2011 | 06:01 PM
Lazukard's Avatar
If some body need the Engineery Sheet Just send my PM ! VERY Usefull when you do your mecanic yourself. Very Easy and reduce considerably the chance do to an error.
I Do my head and my Timing myself with this sheet and I never follow lesson in mechanical.
Old May 23, 2011 | 06:31 PM
Thanks for the extra pics of the radiator
Yeah I've got one of those 1500 page service manuals (thanks to a good friend ) to much info to take in lol
Back to the injectors, mine look like this...
Are you the original owner of your ra ?
