04-06 Ralliart Engine/Drivetrain (no forced induction)
CAI Filter Change
Old Jul 9, 2011 | 08:54 AM
cameronh88's Avatar
CAI Filter Change
I've got an 04 ralliart with the injen cai, and it badly needs a new air filter (it looks beyond cleanable). Will I have to remove the front bumper to just change the air filter, or has anyone been able to get to it any other way (maybe by removing the headlight)?
Old Jul 9, 2011 | 11:19 AM
lanzerralliart's Avatar
EvoM Super Moderator
I was raised throughout middle TN , where are you at? But to change the filter , jack up the front end, (use jack stands) undo the black plastic clips that are on the bottom driverside splash guard, once that section is off you should be able to get to the filter, take it off and put the new one ... this the part number if you want the same one from injen,
INJ-X-1013-BR and here is the injen hydroshield part number X-1033BLK for said filter incase your interested in more assurance from water getting in your motor.
Old Jul 9, 2011 | 01:04 PM
Antonovich's Avatar
you would have to remove the bumper to remove the headlight anyway...
Old Jul 9, 2011 | 01:48 PM
nerdbotSKRA's Avatar
I would thinj its done the same way you change the driver side fog light, right?
Old Jul 9, 2011 | 02:32 PM
yeah pretty much as I explained...
Old Jul 10, 2011 | 07:29 AM
Beardly P's Avatar
Hail to the Beard
This. Not sure how effective the hydroshield is by itself, but also look into getting a bypass valve.
Old Jul 10, 2011 | 07:31 AM
Parks's Avatar
Filter is actually pretty easy to get at once you remove the small splash apron. I totally recommend get the Hydrosock from Injen to go over your filter. Not only helps keeps the water out but all the other crap while your driving.
Old Jul 10, 2011 | 01:08 PM
cameronh88's Avatar
Thanks. Glad to hear the bumper will be staying where it is. Lanzer, I live in shelbyville. It's about 30 mins south of murfreesboro.
Old Jul 10, 2011 | 06:26 PM
Wow I lived in shelbyville , then moved to unionville then to south Florida it was a culture shock at first but it's all good now lol, ok enough off topic that's just kinda cool though outta all of the cities ....
04rallikid
Jul 6, 2012 07:27 AM
Slovak
Oct 18, 2005 08:07 PM
Z_Lancer_Man
Jan 26, 2005 07:53 AM
JoeFriday
Lancer Troubleshooting
May 29, 2004 05:30 PM
drumgod
Feb 1, 2004 09:03 PM
