Radiator
Radiator
As you know my radiator craped on me a couple of weeks ago so I replaced it with a Spectra radiator from Autozone. The core is way thinner then the oem one. The problem I'm having is on the highway under normal acceleration it heats up a lot, but if I'm in traffic or at the stop light it cools ok. I've checked all over the place and I see that these Spectra radiators are the most popular ones. The question is do I have a bad radiator or due to the thinner core size it cannot cool fast enough under acceleration?
im thinking of going mishimoto. i already have a separate trans cooler that i purchased from NAPA so just got to find time/money to get the new radiator but that is always another option for him
he actually already has an extra , external trans cooler like you said but I think there is another complication with doing that if I'm not mistaken.... Dacib shoul be tuning in soon
The extra transmission cooler that I have is to small to cool the fluid on it's own, it's 10x5in. So to get the MIshimoto or Megan radiator it would cost me around $400 for everything and I would have to deal with custom fitting the fans. I think it's to much ...
It does cool as soon as I take my foot of the accelerator but when I accelerate it heats up again.
I've replaced the cap last night but that didn't make a difference. I have a 170 thermostat and I was reading last night that in some cases this is causing the car to overheat under acceleration since the coolant doesn't stay long enough in the radiator to cool off. I will put back the original thermostat tonight and see if that will fix my issue.
So I put back the oem thermostat and I even replaced the radiator with a new one and it's still the same. I can't believe that this POS Spectra radiator is everywhere: Autozone, AdvanceAuto, Napa, Pepboys, Autoparts warehouse, etc. they all have only this one except Autopartswarehouse but all the other radiators online are as thin as this one. I called the stealership and they want $600+ for the oem one. Looks like I'll have to go with the aluminium one and get a bigger transmission cooler...
