Releasing clutch lightly to shift? Weird
Hey guys, well sometimes when I shift into first or reverse, it won't go into place, but if I start letting go of the clutch while pushing the shifter in at normal force, it'll slide in Gear perfectly. Any ideas why?
Assuming this only happens when you're at a dead standstill, this is easy. The teeth on your gears will most of the time mesh no problem, but once in a while will go peak-to-peak instead of peak-to-valley. Lightly releasing the clutch starts moving one of the gears, so they break this deadlock, and then mesh like normal.
change gear oil?? drain and refill...there's two bolts, one is the drain hole, and one is the fill hole...
https://www.evolutionm.net/forums/04...lper-pics.html
idk where haha, I'll figure it out!Edit: didn't see the link, thank you!
