04-06 Ralliart Engine/Drivetrain (no forced induction)
Rev. problem
Old May 9, 2012 | 11:03 AM
zeft12's Avatar
Rev. problem
hey guys 2 days ago my 2006 4g69 started to cut while driving, rev. problems also started to show up
here is a video... any ideas?
http://www.youtube.com/watch?v=Uejoo...ature=youtu.be
Old May 9, 2012 | 12:30 PM
Ralliartize It's Avatar
Is there a CEL?
Old May 9, 2012 | 12:59 PM
Darewood's Avatar
There is a CEL on the dash lit up. Since it's an 06 and when the rev goes all crazy its when mivec engages. Maybe it is having issues engaging? But check the code to see what it is.
Side note: That is a lot of miles...wow...
Old May 9, 2012 | 02:28 PM
zeft12's Avatar
No codes except for the auto. ECU on manual trans.
It's not actual millage, I got this clusters in KM/h instaed of my original showing in miles.. actual miles should be around 50K
Old May 9, 2012 | 02:34 PM
Raikiri's Avatar
wait... this actually runs a car? might want to get the proper ECU for the car first.
unless the ECU is what's throwing the code your car is throwing some sort of code cause the CEL is on
Old May 9, 2012 | 02:49 PM
zeft12's Avatar
I'm using this ECU for more than 3 yrs now, no problems at all.
The only code am getting is P1751
Old May 10, 2012 | 11:17 AM
zeft12's Avatar
update: Finally it showed P0300-Random/Multiple Cylinder Misfire Detected
Long list to check ...
Old May 10, 2012 | 11:55 AM
Replacing the plugs should cure your 0300..
The P1751 I have never encountered before....
Old May 10, 2012 | 12:24 PM
mikegutt's Avatar
Second the changing of plugs, mine was having trouble revving past, threw the misfire code, and i changed the plugs, now its been running fine.
Old May 10, 2012 | 01:54 PM
zeft12's Avatar
check list for tomorrow:
- Faulty spark plug (s)
- Faulty ignition coil (s)
- Ignition coils harness is open or shorted
- Ignition coils poor electrical connection
- Clogged or faulty fuel injectors
- Injectors harness is open or shorted
- Injectors poor electrical connection
- Improper spark plugs
- Insufficient cylinders compression
- Incorrect fuel pressure
- Intake air leak
Read more: http://engine-codes.com/p0300_mitsub...#ixzz1uVCv5g2h
Old May 10, 2012 | 01:57 PM
zeft12's Avatar
the P1751- Make specific (Transmission) is due running manual trans. on auto. ECU
moparfan
Mar 27, 2017 08:42 PM
lancerevolution
Sep 13, 2013 09:31 PM
tristanq
Future Lancer / Evo Models
28
Sep 19, 2012 08:56 AM
TopLevelPerformance
Nov 7, 2011 07:33 AM
