04-06 Ralliart Engine/Drivetrain (no forced induction)
ignition problems
Old May 29, 2012 | 01:59 PM
turboart's Avatar
ignition problems
I'm getting no fire at my coil packs. I had drove around all day no probs till I got ready to go home and if simply wouldn't start. Started checking things and my coil packs don't fire. What do I need to do to get to the bottom of this?
Old May 30, 2012 | 07:15 AM
CrAnSwIcK's Avatar
any codes?
check that there aren't any sensors unplugged...there's a few sensors that if not connected will not allow the engine to start, but how the ECU prevents ignition, be it spark or fuel, i don't know...
Old May 30, 2012 | 10:06 AM
turboart's Avatar
I dont have anything to read codes and I can't take it anywhere to have it done. I would have already if I could. I've check all plug I could find
Old May 30, 2012 | 10:14 AM
fastyouth1313's Avatar
Ignition fuse by your left knee on the driver side behind the coin tray. It pops a lot if not there check the underwood fuses if everything is still good..... Probably the dreaded crank position sensor or can angle sensor, let's hope it's one of those 2 fuses
Old May 30, 2012 | 02:38 PM
turboart's Avatar
I checked fuses underhood theyre all good i hope its a fuse though. I just changed the timing belt and the crank sensor is not something i wanna dig back into
Old May 30, 2012 | 04:27 PM
rickylancer's Avatar
if not that on your ignition there is the electrical part on the back of it. i had a very similar problem and when i changed it, it got beteer... mine was so bad it started sparking everytime i switched it over and it wouldnt turn on
Old Jun 2, 2012 | 11:07 AM
turboart's Avatar
i got a code reader from a friend and it pulled a p0340 and said camshaft sensor. Does anyone know how to test the sensor itself. It makes sense because my turbo has been leaking oil from the seals inside and I have allowed the oil to be low at times. I know lack of oil on the cam sensor can induce failure.
Old Jun 2, 2012 | 11:41 AM
turboart's Avatar
I read somewhere that the crank shaft poistion sensor is actullt yhe cause of that code. I cam shaft sensor with a.voltage meter and screwdriver and it was getting a read I assume due to voltage chqnges when the.screwdriver passed it. I not sure what to trust
Old Jun 2, 2012 | 12:08 PM
CrAnSwIcK's Avatar
do you have the book? trouble shooting this code requires a fair bit...step 1 involves an oscilloscope...
Old Jun 2, 2012 | 04:03 PM
turboart's Avatar
I've tried to find a repair manual with no luck. i checked for TDC cuz I recently changed my timing belt and all that comes with it. it seems that jumped timing. I got that straightened out and im getting fire but it still won't crank. I'm gonna do a compression test but I don't know the specs. what should the compression be?
Old Jun 2, 2012 | 10:01 PM
CrAnSwIcK's Avatar
164-226psi, and all within 14psi of eachother
Old Jun 3, 2012 | 04:52 AM
OttRalliart05's Avatar
If that is the code the sensor is done. If ecu does not know know where the cam is it cant fire the coils.
Old Jun 3, 2012 | 10:44 AM
CrAnSwIcK's Avatar
yeah, unless you have all the equipment to analyze electrical/electronic signals, it's pretty much remove and replace...
straight from "the book":
TROUBLESHOOTING HINTS (The most likely
causes for this code to be set are: )
• Camshaft position sensor failed.
• Open or shorted camshaft position sensor circuit,
or harness damage, or connector damage.
• ECM failed. <M/T>
• PCM failed. <A/T>
Old Jun 3, 2012 | 11:25 AM
turboart's Avatar
Im gonna replace it too, but compression test show 0 on two cylinders
Old Jun 3, 2012 | 11:54 AM
CrAnSwIcK's Avatar
pour some oil into the cylinder and retest...this will tell you if it's valves or not...
