04-06 Ralliart Engine/Drivetrain (no forced induction)
car wont catch to start. help please.
Old Dec 18, 2012 | 01:13 AM
speeddemon50's Avatar
Unhappy car wont catch to start. help please.
Hello everyone, i have an 05 RA and when i try to start my car it cranks but doesnt catch. I just replaced the alternator and battery. The fuel pump is pumping the fuel. Doesnt anyone know whats going on or has had this problem before?
Thanks for the help.
Old Dec 18, 2012 | 03:56 AM
lanzerralliart's Avatar
EvoM Super Moderator
Have you checked the starter?
Old Dec 18, 2012 | 04:47 AM
deathsythe99's Avatar
Its not the timing belt is it? Check that s#%t
Old Dec 18, 2012 | 05:25 AM
CrAnSwIcK's Avatar
lol! sorry i know your pain...but it is possible...
deathsythe makes a good point, take the upper timing cover off and make sure the timing belt is turning...
Old Dec 18, 2012 | 07:13 AM
rzrxn's Avatar
i'm not mech-savvy so i say try these:
http://www.dummies.com/how-to/conten...ont-start.html
if those don't work then someone here will have an answer for sure
Old Dec 18, 2012 | 08:14 AM
slc-ralliart's Avatar
Check your fuses as well. I had two fuses blow under the dash a couple months ago. The car would crank all day and wouldn't catch just like yours. Replaced the fuses and everything worked great.
Old Dec 18, 2012 | 08:56 AM
CrAnSwIcK's Avatar
if it cranks but doesn't start, you want to check timing belt, and fuses before you continue cranking....also some sensors will not allow the car to start if they have failed or are unplugged...i believe it's the cam angle sensor i unplugged when i installed my turbo, to pump oil through everything before starting the motor...
Old Dec 18, 2012 | 11:05 AM
Thanks for the help, im going to try and figure out which one it is, hopefully its something small like the fuses. Also, when all this happened i had my battery tested and they said i had a full charge but a cell was burnt. Would that have anything to do with all this also?
Old Dec 18, 2012 | 12:29 PM
Ok, I checked the fuses, there all good. When Im cranking the car the timing belt doesnt move.
Old Dec 18, 2012 | 01:12 PM
CrAnSwIcK's Avatar
if the starter motor engages the flywheel and cranks the motor, the starter and battery are fine. seems your timing belt is stripped or broken, stop cranking the motor. you're sure the starter is engaging the flywheel?
Old Dec 18, 2012 | 01:22 PM
Yeah, is engaging.
Old Dec 18, 2012 | 01:51 PM
CrAnSwIcK's Avatar
timing belt failed
Old Dec 18, 2012 | 10:01 PM
timing belt failed
Yep, took off underdrive pully and saw the timing belt grooves were falling off. Thanks for the help cranswick and everyone.
Old Dec 21, 2012 | 08:17 AM
Thomar's Avatar
See, another timing belt failure. Now I'm getting paranoid.
Old Dec 21, 2012 | 08:57 AM
otter's Avatar
EvoM Administrator
Timing belt should be fine as long as you replace it on time, do it correctly, use a quality belt, and replace the tensioners as well. I did mine every 60k on the button, with OEM belts and new OEM tensioners every time. Never had a problem until Smike somehow managed to break the serpentine belt
