04-06 Ralliart Engine/Drivetrain (no forced induction)
rough 2-3 shift
Old Jul 21, 2013 | 03:49 PM
Dambay's Avatar
rough 2-3 shift
hey. I recently encountered this problem when shifting from 2nd to 3rd at high rpm. I get a bit of a grind going into third from second but only at high rpm, shifts perfect just casual driving. anyone had this problem and found a fix?
Old Jul 21, 2013 | 06:18 PM
slc-ralliart's Avatar
When was the last time the tranny fluid was changed? I'd start there.
Old Jul 21, 2013 | 06:56 PM
CrAnSwIcK's Avatar
go to RTMRacing.com and search Redline MTL, buy 3 quarts and change the fluid. transmission take 2.3 quarts but 2.5 will be fine, which is easy if you only jack the front end. i like to over-fill slightly...
MTL is perfect for all-season driving, doesn't get too thick in the winter and performs very good even when it's very hot.
i had a wickid grind and since i switched to redline, i haven't had a problem shifting quickly at 7300 rpm.
Old Jul 22, 2013 | 01:53 AM
Dambay's Avatar
I figured it could be a fluid issue, syncro slipping slightly and not matching gear speed. I will definitely try changing out the fluid.
josh_evo9
14
Oct 24, 2016 11:58 AM
Richard.Son
Apr 24, 2016 10:10 PM
raywong
40
Sep 16, 2015 03:49 PM
Christoforo
Dec 3, 2008 01:08 PM
wrxrocks
22
Nov 8, 2005 06:56 PM
