04-06 Ralliart Engine/Drivetrain (no forced induction)
Idle issues but no stalling
Old Sep 26, 2013 | 09:24 AM
zakdamunky's Avatar
Okay so I have an 06 Ralliart at 106,000 miles and the engine runs fine while cold. Once it warms up and I come to stop the idle tends to fluctuate from 600-1000 rpm. At approximate 750-1000 the car sounds fine. When it drops below 750 it sounds like my car is making a knocking noise and it feels rougher than it should with polyurethane motor mounts. When I feather the gas and raise the rpm to 1000-1200 the car feels perfect at idle. Any idea as to what the cause of the this noise is and why its dropping below 750rpm? My mods at the moment are as follows:
Custom downpipe and catback exhause
SRI
Lightweight Flywheel
UDP
RRM ecu upgrade
Any suggestions?
Old Sep 26, 2013 | 11:53 AM
lanzerralliart's Avatar
EvoM Super Moderator
Not sure of the issue but I raised my idle with the reflash to 1k for this reason, in 2010.
Old Sep 26, 2013 | 01:45 PM
CrAnSwIcK's Avatar
by any chance have you ever filled the tank to the rim and had trouble starting the engine?
Old Sep 27, 2013 | 06:36 AM
zakdamunky's Avatar
@Cranswich
I don't believe I have ever overfilled the tank and its never given me any problems starting either. Can the idle be adjusted through the RRM Piggyback I have installed?
Old Sep 27, 2013 | 07:11 AM
CrAnSwIcK's Avatar
there's your problem right there....
are you running a wideband?
Old Sep 27, 2013 | 07:40 AM
zakdamunky's Avatar
no I'm not running a wideband. The piggyback has been in my car for a year and half now but just started idling weird about 3 months ago and it is on and off.
Old Sep 27, 2013 | 08:58 AM
rzrxn's Avatar
maybe you have a leak in your system somewhere?
or some of the wires that connect to the piggyback are loose?
first, i think you should try to double-check all your connections and if the flow is good.
after that, if it still persists, you gotta dig deeper (eg. piping measurements, air flow, etc.)
hope that helps...
Old Sep 27, 2013 | 09:20 AM
zakdamunky's Avatar
I don't think there is a leak. My buddy tested for a leak when it started happening originally and its hasn't thrown a CEL for a leak. I double checked all the wires a week or 2 ago and didn't see any problems:/
Old Oct 2, 2013 | 07:07 AM
zakdamunky's Avatar
I still haven't been able to pin point the issue:/ I thought maybe it was my heatshield coming loose again since it sounds like its right under my shifter but that wasnt the case. I will try and post a video later so you can hear it.
Old Oct 4, 2013 | 08:49 AM
CrAnSwIcK's Avatar
reset the piggyback and ECU...
Old Oct 4, 2013 | 09:28 AM
zakdamunky's Avatar
I will try resetting it over the weekend once I get my laptop back. Does anybody know if you can change the idle rpm through the piggyback?
Old Oct 4, 2013 | 01:11 PM
CrAnSwIcK's Avatar
idle RPM is targeted in the ECU ROM, and various signals contribute to the calculation...if it's idling outside of spec, something is wrong...I would blame the piggy back first...then I would start looking at the evap system if you're sure there's no intake or vacuum leaks...
Old Oct 13, 2013 | 09:47 PM
chaseman589's Avatar
So a wideband is highly recommended if looking to purchase a piggyback for the ecu? the spending never ends
Old Oct 14, 2013 | 06:44 AM
CrAnSwIcK's Avatar
any time you do any tuning you need a wideband...every change you make to timing, you need to correct the AFR...you won't know what your AFR is without a wideband...
jennz03
Lancer Troubleshooting
Feb 20, 2017 08:15 PM
btownsoccer22
Oct 21, 2011 10:31 PM
bobaab
Dec 24, 2006 11:57 AM
RREvo
Aug 21, 2005 05:17 PM
