04-06 Ralliart Engine/Drivetrain (no forced induction)
Clutch disc 4mm too small in diameter - potentially problematic?
Old Jan 2, 2014 | 12:12 PM
doncarbone's Avatar
I'm doing an awd swap on the 4g69 by using a 5spd awd transmission system from an Outlander.
Reading up on clutch specs of the Outlander, i'm seeing that the stock clutch is identical to that of the ralliart with the exception of a slightly wider clutch disc: diameter 228mm versus 224mm.
The ACT clutch disc that I have now in my Ralliart is 224mm although I'd ideally, along with my Clutchmasters flywheel, just swap these into the new Outlander transmission....
Am I at any sort of risk using this 224mm clutch versus a 228mm?
Old Jan 3, 2014 | 03:10 PM
CrAnSwIcK's Avatar
does the outlander disc and pressure plate fit on our flywheel? if not then just use the ralliart clutch and flywheel...I don't know what there is for aftermarket/racing clutches for the outlander...
Old Jan 3, 2014 | 05:51 PM
doncarbone's Avatar
yes it should.
apparently the pressure plate for the ralliart has a higher clamping force and release load, but the dimensions of each system are identical.
Old Jan 3, 2014 | 06:21 PM
CrAnSwIcK's Avatar
just use the ralliart clutch then, the input shaft should be the same for both.
Old Jan 4, 2014 | 10:24 PM
doncarbone's Avatar
yes looks like this is going to work
doncarbone
Apr 21, 2020 01:15 PM
MrRalliart09
Sep 28, 2017 10:22 AM
Krakker
Outlander Sport
12
Dec 27, 2015 05:53 PM
doncarbone
157
Oct 8, 2015 01:28 PM
kericr
Jun 8, 2005 02:11 PM
