04-06 Ralliart Engine/Drivetrain (no forced induction)
Trans fluid
Old Jan 21, 2014 | 06:11 PM
BrunoBoy650's Avatar
Trans fluid
What's the recommended fluid for our trans? For dsms I use MTL mixed with Mt-90. My RA has 194,xxx and is now becoming notchy....
Old Jan 21, 2014 | 06:35 PM
RalliartN's Avatar
what is it with this generation? search and read - this topic has been done to death in the RA sections
Hey, don't mind trying to help, but first get a bit educated by reading the past discussions... just seems like we have to start every topic from scratch again and again.
Old Jan 22, 2014 | 11:09 AM
Saw a thread you commented in. You state synchromesh or MTL.... Have you mixed MTL with MT-90 before? Does it perform as well as it does in dsms? How many quarts does this trans take anyhow? The search function looking per sub category comes up with nothing when I use "fluid" as a keyword in lancer general or drivetrain sub forum....
Old Jan 22, 2014 | 12:14 PM
CrAnSwIcK's Avatar
what ratio do you mix MTL with MT-90? why not just run MT-85?...I've used a lot of different gear oils, and I've had the best results with redline....
Old Jan 22, 2014 | 12:20 PM
Ryan.Kauz's Avatar
I vote for this guy to be our president!!! (seriously)
Old Jan 22, 2014 | 08:53 PM
On the dsms I used a qt of MT-90 then a qt of MTL and top off with MT-90. Transfer cases and rear dif would be Heavy shockproof.
Old Jan 23, 2014 | 05:02 AM
CrAnSwIcK's Avatar
no t-case or rear diff here, lol...that ratio is pretty close to 1:1, as the trans will take 2.3 qt, so it's almost like running MT-85 anyways (was made by redline so 50/50 mixing of MTL and MT-90 is no longer necessary)...you live in a warmer climate so it should be ok, up here, even MT-85 feels like the tranmission is full of ice cream at -20 celcius
Old Jan 24, 2014 | 12:10 PM
MT-85 it is thanks! Lol
Old Jan 24, 2014 | 12:37 PM
mikemike396's Avatar
No love for BG-Synroshift II?
I personally think its amazing.
Old Jan 24, 2014 | 01:40 PM
jhoganusaf's Avatar
i use Amsoil for everything.
Old Jan 24, 2014 | 04:03 PM
CrAnSwIcK's Avatar
amsoil manual transmission fluid is OK...I use nothing but amsoil in the engine, but had better results with redline in the transmission...never tried synchro shift II, but it's like $10 more a quart than the redline.
Old Jan 24, 2014 | 05:12 PM
slc-ralliart's Avatar
I ran both Redline MT-90 and BG syncroshift. BG is my favorite and will stay in the tranny as long as I have the car.
Old Jan 24, 2014 | 05:28 PM
CrAnSwIcK's Avatar
MT-90 (75w90) is a lot thicker than synchroshift II. MT-90 is better suited for racing, where oil temperatures would be higher, as it takes some warming up to perform well, that's why in the past people mixed MT-90 with MTL, to get the "85 viscosity" as a happy medium for casual track, and daily street driving. Now redline sells MT-85 in its own bottle. BG synchroshift II is 75w80, the same viscosity rating as redline MTL...so you would likely be just as happy with redline MTL.
Old Jan 24, 2014 | 06:00 PM
I don't think someone could go wrong with either. I may have to give the 85 a try next time.
Old Jan 24, 2014 | 09:16 PM
CrAnSwIcK's Avatar
I want to try the BG myself, but I wanted to try the MT-85 first after great success with MTL...though I track the car occasionally, I still may go back to a thinner oil, I'm not changing transmission oil with the seasons, and the MT-85 is just a tad thick when the temperature drops below zero.
