04-06 Ralliart Engine/Drivetrain (no forced induction)
? about rrm intake i baught
Old Mar 6, 2004 | 04:02 PM
ski10804life's Avatar
Question ? about rrm intake i baught
Hey guys whats up, i just abught the rrm cold air intake it looks awsome. I installed the top half within like 15 min and then i have spent like 10000 hours trying to find out where the secong half of the piping bolts on. I have tried to fit it in every different way, and the only way it fits right is where the filter is pointing twards teh back of te car and it is like under the car. So i said that cant be right. I called road race all day i guess they close early on saterdays because i cant get ahold of them. Does anyone know hwo to isntall this or has directions to do it because mine never came with installation directions, thanks alot guys.
Old Mar 6, 2004 | 04:09 PM
jaymz916's Avatar
I got the aem cai took like 20 min to install, pm me if you want some pics of piping, where it runs.
Old Mar 6, 2004 | 04:24 PM
jaymz916's Avatar
piping runs from the throttle body into the maf, then second peice runs from maf down past battery and will curve towards under driver side headlight.
Old Mar 6, 2004 | 04:25 PM
jaymz916's Avatar
this is where it's making the turn towards driver side, can see tranny
Old Mar 6, 2004 | 04:27 PM
jaymz916's Avatar
end of piping where filter is attached, has a little bracket attached, and if you did it right, that bracket will line up perfect with a pre drilled hole on frame where the supplied bolt will hold it into place. Hope this helps
mitsumichael7's Avatar
OK, the RRM cold air bolts to the tranny. I got a good look at the one they had at the meet. Wish I could convey it better but I made my own intake so my mounting is different.
Old Mar 6, 2004 | 04:28 PM
imapunkclaimer's Avatar
your ralliart is manual right?
jaymz916's Avatar
It shouldn't bolt to the tranny, just piping runs along side of it. Look at the last pic.
Old Mar 6, 2004 | 04:30 PM
yeah it is manual, And i dont know where ont he tranny it is suposed to bolt onto haha i am really confused
Old Mar 6, 2004 | 04:31 PM
jaymz916's Avatar
dude, I totally didn't notice that you had a ralliart, I got an oz rally, even though the setups should be kinda similar, sorry, hope it helps anyway.
Old Mar 6, 2004 | 04:32 PM
yeah i have a ralliart
Old Mar 6, 2004 | 04:33 PM
and im having alot of trouble
Old Mar 6, 2004 | 04:34 PM
jaymz916's Avatar
Looking at the ralliart engine, the setup looks like I said, pretty similar, but the piping looks way shorter than the kit for the oz, If the piping has that bracket, then there should be a pre-threaded hole on the frame where it'll line up with.
Old Mar 6, 2004 | 04:35 PM
there are 2 sets of piping and i dont know if i have the piping lined up the right way let me go look at it again and i will let you guys know how it goes i will replay in 5 minutes
Old Mar 6, 2004 | 04:37 PM
jaymz916's Avatar
First pipe, smaller of the two runs between tb and maf, second runs from maf down and bolts to frame. then again, haven't seen the ralliart setup, someone please correct me if i'm wrong, i'm just speculating here.
