04-06 Ralliart Engine/Drivetrain (no forced induction)
Help!!!! Have to smog car
Old Jul 30, 2014 | 01:37 PM
RALLIART15's Avatar
So as the title says I have to do a CA smog on my car, never anticipated needing this so I tossed my cat when I went to high flow 8 years ago...
So I ask, does anyone have a OEM cat laying around I can buy/borrow????
Old Jul 31, 2014 | 05:27 PM
CrAnSwIcK's Avatar
if it's still catted, won't it pass?
Old Jul 31, 2014 | 05:41 PM
RALLIART15's Avatar
Unfortunately no.. It's a 49 state high flow...
CA is the most strict on smog bs that they won't pass most high flows or aftermarkets when they put the sniffer in the exhaust.
Old Jul 31, 2014 | 06:15 PM
Cal City Evo's Avatar
Wrong. I passed with a HFC the last time on my evo and I expect to do so the next time. If it looks stock they won't give you any grief.
Living in CA NEVER get rid of your smog stuff you take off. You are finding out that you need it again.
A crappy tune would cause you not to pass. If you are running well and no CEL's you shouldn't have any problems.
Old Jul 31, 2014 | 07:50 PM
RALLIART15's Avatar
Is it a 50 state HFC?
Only reason I don't have a CEL is cuz I have the CEL eliminator bung on the rear O2 with out it it throws the code.
I was on the easy coast when I did it and never thought I'd move here but apparently life is funny like that.
Old Aug 1, 2014 | 05:44 AM
CrAnSwIcK's Avatar
might have to bite this one and buy a cat.
Old Aug 1, 2014 | 10:50 AM
RALLIART15's Avatar
Yup but hoping to avoid it as a new one is $1000 from the dealer and two months out. Apparently there aren't any in the country.
Old Aug 1, 2014 | 10:53 PM
Cyp's Avatar
Cyp
There are some stock cats for sale
Old Aug 1, 2014 | 10:58 PM
RALLIART15's Avatar
I assume you mean on here?
I have only found them for base lancers not the 2.4 Ralliart.
If you found one tho if appreciate a link.
Old Aug 2, 2014 | 06:08 AM
CrAnSwIcK's Avatar
why does it have to be OEM? if your stock cat got clogged or was faulty, and you took it to "joe's exhaust shop" (made up name) and had a new one welded in, it should be fine, no?
Old Aug 2, 2014 | 11:00 AM
RALLIART15's Avatar
That's what one would assume so I called the muffler shop and asked. He got on a air resource board website or something like that and california hasn't approved any universal obd2 cats to be used. So the muffler shop even stated have to go to the dealer.
Old Aug 2, 2014 | 12:11 PM
CrAnSwIcK's Avatar
weak...I left my stock cat at the shop when I had my downpipe fabricated, so I'm out... good luck man.
Old Aug 2, 2014 | 12:19 PM
RALLIART15's Avatar
Thanx
Old Aug 5, 2014 | 03:15 PM
Tw3NTy0n3's Avatar
Is that something that's new? Have you called other muffler/smog shops for different opinions?
I used to take mine to a shady shop that passes it no matter what for a hundred bucks but last year I got a letter saying I needed to take it to a S.T.A.R. Shield certified shop or something like that. They're very strict.
I ended up getting my hands on a stock header/mid pipe and then paying a shop to finish off the exhaust with a universal cat and kept my aftermarket muffler. After they checked everything inside and out they passed me with no issues.
I would definitely call around first.
Old Aug 5, 2014 | 03:38 PM
bphx123's Avatar
pm me OP. I'm in south bay ill give u more info.
