04-06 Ralliart Engine/Drivetrain (no forced induction)
Right Side Engine Mount Studs Sheared Off
Old Mar 22, 2015 | 10:51 AM
milothicus's Avatar
I have a 2006 Lancer Sportback, which is a station wagon that has the 2.4l engine.
yesterday i was driving on the highway, and it started making more nose, and the vibration through the gas pedal increased. i pulled off the highway and had the car towed to a Canadian Tire (only place open on the weekend).
Turns out the three studs on the block that the right side engine mount attach to have all sheared off. one had clearly broken a while ago, and the other two both look like they broke very recently. not too surprising that the third would go not long after the second.
the store is going to try to get a mount from the dealer, but i don't see the part with the studs in it in the FSM.
has anyone dealt with this part? can it be removed from the block and replaced separately from the rest of the engine mount? would it be better to take it to my normal independent mechanic to replace the studs?
Old Mar 22, 2015 | 11:23 AM
CrAnSwIcK's Avatar
to change the bracket, you need to remove the timing belt, big job, and if it's crappy tire doing it, you might as well buy a new car...it would be much easier to either extract (if possible) the broken studs, and install new ones...even still you can drill the old bolts right out, and tap the holes, then install new studs....
part number for studs - MR984438 - they are M10x35, if you can find generic class 8.8 or 10.9 fasteners...
Old Mar 23, 2015 | 06:48 AM
milothicus's Avatar
That's what I was afraid of. Well, I had caa tow it to my mechanic this morning.
Hopefully he can fix it without taking out the timing belt.
Old Mar 23, 2015 | 05:00 PM
RalliartN's Avatar
Hotsauce101
Sep 28, 2013 11:24 AM
DubsE46
12
Sep 12, 2011 11:25 PM
Aman
Aug 26, 2010 10:43 AM
fuzzychi
Jun 20, 2010 08:40 PM
steven88
14
Jun 11, 2010 11:17 PM
