Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
How to remove sheared nut on top of front strut?
Old Jun 11, 2010 | 01:47 AM
steven88's Avatar
Hey guys I accidentally screwed up taking this nut off....and now its all sheared up...no matter how hard I try, I can't get my 14mm back on top...it just keeps slipping off...
I'm hoping others had this issue and know a quick and simple solution....btw I tried fitting some vise grips on there, and damnit theres no room to work down there
Old Jun 11, 2010 | 08:31 AM
p.phresh's Avatar
looks like there's a bit of bite left on the bottom? Get a deep socket and try again. If that doesn't work get a smaller socket and hammer it on there. And if you're at wit's end.... cut the thing off with a dremel.
Old Jun 11, 2010 | 08:47 AM
rcheung's Avatar
Agreed , looks like a bigger size deep socket could fit below the 14mm part.
Old Jun 11, 2010 | 08:54 AM
buchnerj's Avatar
They also make wrenches/sockets that are specially designed to take stripped nuts off of threads.
http://www.craftsman.com/shc/s/p_101...Mechanic+Tools
That second one is from my tool box. I couldn't find it online. It is still a craftsman though.
Old Jun 11, 2010 | 11:41 AM
dyezak's Avatar
I vote the following:
1 case of beer
1 video camera
1 10lb sledge hammer
1 OxyAccetaline rig
I don't care what you do, just use the video camera and use the rest of the tools to get the nut off. Hilarity will ensue.
Old Jun 11, 2010 | 01:18 PM
steven88's Avatar
mmm...whats that wrench called? it looks interesting
and btw, you guys think a dremel is strong enough to cut through? i might just dremel that ***** off....because I can't get a hammer to fit in there
Old Jun 11, 2010 | 01:22 PM
SilverShadow03's Avatar
You can also use these. I've used this before on my old Acura and it worked like a charm.
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
Product Description
10 low profile removers, fits sizes from 3/8 to 3/4 in. and 10 to 19mm. Used for removing damaged, stripped, rusted or painted fasteners (screws/nuts/bolts) of all types.
* Designed for use in areas where space is limited as well as standard use
* Can be used with a combination wrench, adjustable wrench, pliers, vise grips, or socket
* Special 6-flute spiral design draws itself onto the fastener allowing it to loosen
* #1 Bolt-Out fits 3/8 in. size fastener; #2 Bolt-Out fits 10mm size fastener
* #3 Bolt-Out fits 11mm and 7/16 in. size fastener; #4 Bolt-Out fits 12mm size fastener
* #5 Bolt-Out fits 13mm and 1/2 in. size fastener; #6 Bolt-Out fits 14mm size fastener
* #7 Bolt-Out fits 15mm size fastener; #8 Bolt-Out fits 16mm and 5/8 in. size fastener
* #9 Bolt-Out fits 17mm size fastener; #10 Bolt-Out fits 19mm and 3/4 in. size fastener
Old Jun 11, 2010 | 01:47 PM
rcheung's Avatar
Have you tried a deep socket yet? A dremel can make a mess of things very quickly.
Old Jun 11, 2010 | 01:52 PM
steven88's Avatar
yeah i tried a deep socket 14mm...and i cant get it to fit the very bottom...and theres no room to smash a hammer in there
Old Jun 11, 2010 | 02:28 PM
wiretap's Avatar
Your deep well socket isn't very deep. You should go to the store and get a deep well socket.
Old Jun 11, 2010 | 06:30 PM
rcheung's Avatar
The bottom half of the nut looks bigger than 14 mm.
Old Jun 11, 2010 | 06:35 PM
FedEvo8's Avatar
Use a chisel or long flathead screwdriver. Use a the screwdriver and hammer to make a "slit" on the nut. Hammer the nut out in direction to loosen the nut. Works everytime.
Old Jun 11, 2010 | 08:45 PM
Finest's Avatar
GATORGRIP!
Old Jun 11, 2010 | 11:00 PM
goevox's Avatar
yeah your best bet is a twist socket like craftsman link few post up.
Old Jun 11, 2010 | 11:17 PM
steven88's Avatar
Hey guys...I was able to get the sheared nut off...thanks for everybody who inputted in this thread
Basically pphresh and rcheung took a look at my sheared nut...and realized the very bottom of the nut still has some bite left intact. They suggested I throw on some PB blaster and mash my 14mm deep onto there...I tried it and vola! worked like a charm.....I guess the PB blaster worked because I remember I tried jamming my 14mm deep socket in there without the PB blaster and it wouldn't budge.
Thanks again ya'll
TommiM
13
Feb 27, 2012 07:59 PM
evohead1
Jan 25, 2012 05:50 PM
adnmoh1
Midwest Region
42
Aug 3, 2011 10:32 PM
elmark44
Jun 30, 2011 10:13 AM
nestoledo
Jul 14, 2010 11:48 AM
