Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Quick question: issue with reinstallation
Old Jan 25, 2012 | 12:05 PM
evohead1's Avatar
Im trying to get my car up and running before work. Does this piece need to be forced together more? There looks to be a little notch where a bolt might pass through but I can't seem to get it closer. Or is that notch not relevant to the bolt. There is rust that might need to be removed but I'm not sure at this point.
[IMG][/IMG][IMG][/IMG]
Old Jan 25, 2012 | 12:51 PM
Kracka's Avatar
Please take a new picture with better clarity and resize it to fit the page.
Old Jan 25, 2012 | 03:37 PM
evohead1's Avatar
Any feedback would be awesome
Old Jan 25, 2012 | 05:02 PM
deludedbuzz's Avatar
I just replaced the ball joint with the whiteline one this past weekend.
And yes that notch should be aligned properly so the bolt will pass through that hole without much if any effort.
You should be able to grab the ball joint with some pliers or a vise (pad it with some rubber if you want) and twist it to get a better alignment of the notch.
Is this what you were talking about?
Old Jan 25, 2012 | 05:15 PM
Although as the other poster said your picture is not clear, but it also looks like the ball joint shaft is stopping at the height of the bolt hole? As I mentioned the notch on the shaft has to be aligned with the bolt hole and the bolt be able to slide easily in.
Old Jan 25, 2012 | 05:50 PM
evohead1's Avatar
yeah that's what i was looking for guys. Thanks!
mclaren
Aug 1, 2016 06:24 PM
SDevo13
Feb 24, 2012 02:25 PM
OZreef
Lancer Aftermarket Forced Induction Tech
81
Sep 28, 2011 10:47 AM
Bones_OZ
Apr 19, 2011 11:02 AM
nestoledo
Jul 14, 2010 11:48 AM
