Replace Engine
I imagine that with slight modification both the regular lancer engine and the Evo's engine would fit. Then again with lots of modification you could probably put a 350 in it so, if you have the money and time you can put just about anything you want in.
if you run a search you might find that Japan has a motor that will go in the car pretty easily. I am thinking the Lancer that isnt the Evo in Japan was offered in a DOHC model and maybe even a turbo DOHC model (not totally sure there) that are not Evo motors. I think I remember reading the turbo model had like 200hp. I dont know for sure though. Check into it.
the regular lancer engine and the DOHC JDM will fit. Unfortunately the Evo engine is built almost the exact opposite (why they did this nobody really knows) but the first 2 and if you're lucky more will fit.
for real why did u buy the car if u just wanna swap the engine?i mean the mivec is pretty impresive peice of craftsmanship,why not just buy a reg lancer an modify the heck outta it if ur gunna do all that?
