04-06 Ralliart Engine/Drivetrain (no forced induction)
Humming noise coming from left front area
Old Feb 25, 2016 | 10:11 AM
Lancerfry30's Avatar
Hey guys,
So I'm getting a weird humming noise from the left front area sounds like a airplane noise. The higher the speed the louder it gets. When the car is in neutral it doesn't go away either.
Side note I'm running D2 coilovers and a 215/45/17 falken G4 tires.
Old Feb 25, 2016 | 01:49 PM
CrAnSwIcK's Avatar
while moving, right? does it change probably the wheel bearing...but does it change pitch when you turn one way or the other, or change your speed?
Old Feb 25, 2016 | 02:27 PM
It's all the time. When it's rotating. 45mph and above when it gets loud. I might check the play in the bearing tonight.
Old Feb 25, 2016 | 09:33 PM
CrAnSwIcK's Avatar
ok, but when the car is not moving, but the engine is running, there is no noise, correct?
Old Feb 26, 2016 | 09:24 AM
Totaly mis read that. Yes when the car is sitting sit. No humming. Only when the wheels are moving.
Old Feb 27, 2016 | 10:37 AM
CrAnSwIcK's Avatar
wheel bearing most likely, did you check for play?
Old Feb 27, 2016 | 11:09 AM
machoymaru's Avatar
Machoymaru
Don't know if this will work, but check for any boost leaks. I've had loud humming noise and it was always boost leeks.
Old Feb 27, 2016 | 06:51 PM
CrAnSwIcK's Avatar
the 2004-2006 ralliart is not turbocharged from the factory.
Old Feb 28, 2016 | 02:45 PM
I checked for bearing play nothing out of the normal. I'm going to take it to a mechanic to double check the noise. That way I'm not going crazy or before I rebuild my whole front end.
Jaxson75
Lancer Troubleshooting
Apr 11, 2015 06:59 AM
ashton13
31
Mar 25, 2010 08:07 PM
Bizo2
Apr 28, 2009 07:20 PM
dgrumpys
Apr 17, 2009 06:19 PM
jrsimon27
21
Jan 29, 2008 09:35 PM
