04-06 Ralliart Engine/Drivetrain (no forced induction)
Timing belt question.
Old May 5, 2017 | 05:39 PM
TuJay's Avatar
So, I have a couple hundred miles on my timing belt left (4G69) and I have a question about taking it off. I printed off the AllData pages for the process but do I need to have something to hold the cam gear in place when I release the tension on the belt? I will line up all the marks and time it before I do this if that has anything to do with it. Thanks!
Old May 7, 2017 | 08:57 PM
CrAnSwIcK's Avatar
if all the timing marks are lined up, you can just take the tension off the belt and remove it, although you'll need to remove the engine mount to actually take it off completely...I must ask why you feel to need to remove it after only a couple hundred miles?
Old May 8, 2017 | 04:04 AM
TuJay's Avatar
it's not after a couple hundred, I have a couple hundred left on it before I'm at a risk of it failing on me
anthonypazsd
135
Apr 2, 2026 12:56 PM
evotris
29
Sep 8, 2013 07:26 AM
Robertv34
Aug 27, 2011 12:55 PM
PSG Evo
16
Feb 6, 2011 09:28 AM
anthonypazsd
Jan 31, 2010 03:01 AM
