Spark Plugs.....Ugh
Old Nov 3, 2004 | 11:37 PM
lkwdkuraj02's Avatar
Spark Plugs.....Ugh
Well, i'm at 15K miles and the book recommends changing the spark plugs. So, not knowing much I went out and bought some spark plugs that supposedly fit my car. Come to find out after having everything taken off, I pulled out the first plug and compared it to what I bought. Not even close. I went around to a few auto parts stores and all were giving me the same size. I called one place and they said their computer said factory only. Which is fine, I don't mind putting in the factory NGK plugs. However, has anyone else used anything else besides? Where did you get them? How much? .... Thanks in advance for the suggestions!!!
Old Nov 4, 2004 | 07:57 AM
lrh35's Avatar
I just took my ralliart to the dealership for its 15k tune up. I don't think they changed my spark plugs. I don't think it needs it this soon.
Old Nov 4, 2004 | 08:43 AM
Well the book recommends changing the plugs at 15K for the "extreme" driving. Also, I took one out, and the ceramic around the plug was crackled.
Also, I called the dealership this morning......they have to order the plugs and i'm looking at $20 EACH!!!....I didn't know this car would be this high maint. I should have bought a BMW....lol...j/k.....
Old Nov 4, 2004 | 09:01 AM
lrh35's Avatar
it has the platinum sparkplugs, so yes $20 per plug is right but they should last longer then 15k miles. Since yours are already out and one is cracked deffinatly replace them. Is it possable that you cracked it when you pulled it out?
Old Nov 4, 2004 | 09:06 AM
No, it's a worn crackle look. If that makes sense.
Anyhow..... www.sparkplugs.com .... $42 for all 4, tax, and 3 day shipping for the stock NGK's..... much better than $80+tax from dealer.... I've never heard of the brand Denso, but they supposedly also have plugs that fit the RA's.
Old Nov 4, 2004 | 10:17 AM
lrh35's Avatar
Sounds good try it out and let us know how much you like them.
Old Nov 4, 2004 | 10:47 AM
Daddymac's Avatar
I thought our plugs were iridiums not platinum??
Old Nov 4, 2004 | 12:31 PM
Yes, the stock NGK's (what I ordered) are Iridium
Old Nov 4, 2004 | 01:15 PM
ralliartpr's Avatar
If somebody needs the parts numbers :
mitsubishi part number - MN158956
NGK part number - LZFR6AI
Denso part number - IKH20
And yes they are expensive.
Old Nov 4, 2004 | 01:23 PM
Eclipse2Lancer's Avatar
Denso is an OEM parts supplier to Mitsubishi. Look around under your hood and you may see Denso emblems on some parts (radiator for example).
Platinum plugs "should" last anywhere from 40k to 60k miles. If you drive under "extreme" conditions, then they should last 20k to 40k miles.
Old Nov 5, 2004 | 05:41 AM
sillypuddy's Avatar
anybody know the copper spark plug part #?
-joe
Old Nov 5, 2004 | 10:43 PM
Merchandise's Avatar
which is better iridium or platinum plugs?iridium sounds cool which has better performance and lasts longer? TY!
Old Nov 6, 2004 | 08:05 AM
turbonutter's Avatar
I believe the iridiums make a hotter spark, while the platinums last longer.
