Optimal Shifting
Old Nov 17, 2004 | 09:02 AM
MitsuSkot's Avatar
Optimal Shifting
What is the ideal RPM to shift with max accelleration in mind? And further more, through all of the gears, to keep those MPH climbing the fastest. do you guys push it to redline?? Do you shift earlier??
thanks
Old Nov 17, 2004 | 10:27 AM
turbonutter's Avatar
Yeah, I go for redline - the engine keeps pulling hard enough to redline to make it worth going all the way. Winding it out further also puts you at higher rpm after the shift, with more power on tap after the shift as well.
Old Nov 17, 2004 | 10:34 AM
lrh35's Avatar
I don't agree. I shift at 6000-RPM. I shift fast enough that my RPMs only drop to about 4500, still well within MIVEC. The Hp and torque start to drop down between 5500 and 6000 RPMs. I'm glad someone brought this up though because I thought that I might be shifting a half second to late and I want other peoples opinions too.
Old Nov 17, 2004 | 10:58 AM
sillypuddy's Avatar
i shift at 4500
-joe
Old Nov 17, 2004 | 11:00 AM
ilovecb23's Avatar
i shift around 6k when like merging onto the freeway, optimal enough to let me mergre safely
Old Nov 17, 2004 | 11:02 AM
lrh35's Avatar
I think we are talking drag raceing
Old Nov 17, 2004 | 11:16 AM
bruce988jl's Avatar
on a track of course... haha, but yea i shift at about 5900 or 6000. Normal driving i shift at 3000
Old Nov 17, 2004 | 11:21 AM
lrh35's Avatar
Road and track said that peak Hp is at 5750 RPMs
Old Nov 17, 2004 | 11:33 AM
This has probably been discussed quite often too, but in letting the engine rev to redline, yes the hp does fall off a bit after 5750, HOWEVER, in lower gears you are making much more tq to the ground because of the gearing. If you shift the engine early, even once the engine is at hp peak, you are still not putting down as much power to the ground as you would have been at redline in the last gear. Thus, you are wasting potential energy, and not getting the most out of your engine.
Old Nov 17, 2004 | 04:48 PM
captain150's Avatar
Exactly what I was going to say. Just because you are in mivec after the shift, doesn't mean you are getting good power. Think, the engine at 6000RPM is moving the car faster than it would be in a lower gear. For this engine, that is true. For a V8 with flat torque and power curves, you usually want to keep the needle in the fattest area of the curves. This doesn't always mean redline, for our engine, close to redline is best.
Old Nov 17, 2004 | 06:43 PM
ralliart86's Avatar
i shift at 3000 normally... around 6200 for racing umm conditions... lol
Old Nov 17, 2004 | 06:45 PM
SlowRyd's Avatar
i shift at 6129 rpms.... i like to be different.
Old Nov 17, 2004 | 06:55 PM
ralliart86's Avatar
lol i dont even think our tach is accurate down that far... its probably like +/- 50
Old Nov 17, 2004 | 09:38 PM
lrh35's Avatar
So I was thinking that 6000 may be a hair late but you are saying that 6000 is a hair early but 7000 is late, right?
Old Nov 17, 2004 | 09:57 PM
Arithmetic's Avatar
Exclamation
im too worried about my gas, i shifit 2500-3500rpm's. I try to stay out of MIVEC at all cost, because gas COST!
