VRS Exhaust Ralliart Catbacks!!!
Old Jun 13, 2005 | 11:38 AM
  #91
blk-majik's Avatar
they are all 3-piece. long piece until the axle, short piece to go under the axle, then the muffler.
bung should be very easy to install if u have the tools. they forgot to put mine on too, until i pointed to the o2 sensor only diff was i was there at the shop!
let us know how it goes. im interested in seeing how good their guess work is =) did you get the larger hangers with it?
btw, where u from SkyGTR?
Old Jun 13, 2005 | 01:21 PM
  #92
SkyGTR's Avatar
I'm down in Kendall, but I leave for college in a couple weeks and then I'll be in Orlando at UCF
Old Jun 13, 2005 | 01:27 PM
  #93
ikpthegame's Avatar
bungs get welded in right? if so ill have to use my friends welder
Old Jun 13, 2005 | 01:36 PM
  #94
blk-majik's Avatar
best to weld it in, yes. if u have access to a welder, should only take a couples seconds
Old Jun 13, 2005 | 10:37 PM
  #95
ikpthegame's Avatar
well since i have to wait for the part, and i know you have there cat back do you think just the axel back part will bolt up for now?
Old Jun 15, 2005 | 04:47 AM
  #96
blk-majik's Avatar
I really doubt it. it uses a different type of clamp.
Old Jun 17, 2005 | 09:16 PM
  #97
ikpthegame's Avatar
well im pissed off, this place sux *****. they made the damn thing 6" to short, man they fking suck ***. so if anyone else ordered from them hope yours works.
Old Jun 17, 2005 | 09:20 PM
  #98
blk-majik's Avatar
wtf? call and ask for dan. they should fix u up. what muffler did u get? if u got something they never put on the RA, there is a bit of guess work, but shouldnt be 6" worth...
where is it short? does it bend above the rear control arm correctly and the muffler is just welded too early? if so, they should be able to fix that pretty painlessly. either way, its a hassle. sorry to hear that =(
Old Jun 17, 2005 | 11:27 PM
  #99
ikpthegame's Avatar
ok, well its about 6"-8" short in the area where the pipe from the cat to the part that goes to the muffler. the pipe is fine over the axel in the back but like i said it was a 3 peice kit and the part that gets held together with a damn clamp is the part thats short. like where you have your resonator is where its short. btw i have a magnaflow can on it, one of the street ones forgot what model though.
Old Jun 28, 2005 | 01:52 PM
  #100
ikpthegame's Avatar
well they said there was a mix up with the jig so they are making a new pipe for me now. but now im pissed that damn flange keeps coming lose in the rear and not it melted my bumber i hope i have enuff to get on that GB for the body kits.
Old Jun 29, 2005 | 06:53 AM
  #101
blk-majik's Avatar
the melting is more due to the larger muffler outlet than anything. mine did a bit, but you couldnt see it unless u were under the car. good to hear that are fixing it tho, even tho its a PITA.
Old Jun 29, 2005 | 08:54 AM
  #102
ikpthegame's Avatar
oh this is not just a little bit of melting, it shifted over and melted the hell out of it.
Old Jun 29, 2005 | 04:12 PM
  #103
jerseyjap's Avatar
i'm gettin the downpipe from rrm, i'm wondering how much shorter it's gonna have to be without the cat?? thinking of getting the muffler resonator to the dp?? any advice , i'd like to get it from vrs since you give good word on them blk, in a couple weeks i'm gettin the ecu also, wondering how much more speed all this may give
Old Oct 23, 2005 | 01:25 PM
  #104
jerseyjap's Avatar
what ever happen to your car
Old Oct 24, 2005 | 01:24 PM
  #105
RalliTrav05's Avatar
This sounds like a great deal. I searcheda all over the site and couldnt find parts for our car! Can someone please help!??!
