Heeeeelp!!!
Old Apr 18, 2005 | 10:13 AM
sillypuddy's Avatar
i would seriously doubt that you bled it fully then.. if you look at the restrictor, you will see that it's pretty big volume..
-joe
Old Apr 18, 2005 | 11:04 AM
Myszkewicz's Avatar
-joe
But you're replacing the restrictor with a thin little hose. That's all the volume you've got to fill, then a little bit of fluid lost for bleeding, and the few drops that leak out when loosening the fittings on the stock line.
Old Apr 18, 2005 | 01:48 PM
bigdoggy_dog's Avatar
There wasn't much for me to bleed either.
Old Apr 19, 2005 | 06:35 AM
sillypuddy's Avatar
<shrug>
i guess i bleed it til fluid came out of the bleeder valve..
better safe than sorry i always say.. fluid is cheap... losing brake power is not
-joe
Old Apr 19, 2005 | 06:37 AM
You need to bleed it till there is a steady stream coming out and no more air.
Old Apr 19, 2005 | 06:09 PM
Myszkewicz's Avatar
Aside from sharing a reservoir, they're totally separate systems. Unless you forgot to tighten a connection and lost ALL your fluid, at worst you'd lose the ability to release your clutch. An un-bled clutch will have no effect on braking power.
