Infinity Speakers
I am purchasing Infinity 6002i 6 1/2" Car Speakers tomorrow, I looked around and found that RA's come with 6 3/4. I don't have the s/s package. I just wanted to make sure what the mounting depth is so that the speaker doesnt get in the way with the window. I remember seeing 2.5" somewhere, but I could not find that posting. The Infinitys I'm getting are supposed to be 2 1/4" mounting depth.
If anyone knows the answer, please let me know b4 I purchase them. Thanks.
the mounting depth on those is 2 1/16". the stock non SSL speaker is actually a EURODIN speaker which is 7". you'll have to search to find a bracket that will keep the speakers from falling in since they (& 6 3/4's) are too small. i fabbed wood brackets & brought the speakers in a little so the windows would roll down. here's a pic:
https://www.evolutionm.net/forums/sh...d.php?t=115777
So the mounting depth is 2 1/16? (unless you cut plastic and...). What if I were to get MB Quart 6.5" EKA116 6 1/2" Car Speakers, mounting depth on those are 1.9". as far as the adapter goes i will probably buy one or make one myself.
if you make your own brackets then you control the mounting depth. i had to make 3/4" thick brackets since my 6 1/2's were 3" deep. then i had to trim the inside of the door panel to make room for the forward mount. if i remember, the stock speaker is about 1.75-2" deep. the mb quart would work perfect. i believe Boston Acoustics makes a shallow speaker as well. check www.crutchfield.com also. they may even have brackets you can use.
Originally Posted by otter
I wonder if Evos have different stock speakers than Ralliarts. 6 3/4" speakers fit perfectly in Ralliarts.
otter
90
Jul 11, 2016 09:23 PM
Spoonie
Nov 5, 2009 09:53 PM
kautiongsr
Dec 11, 2008 06:42 PM
EmoEvo
Jul 14, 2002 10:25 AM
