help with 52mm guages
Old Apr 23, 2005 | 10:40 PM
lucky04's Avatar
ok guys heres the deal im hooking up a air/fuel ratio meter, volt meter,and tach. my question is for the tach you have to hook to the coil well we have 4 of them so i was wondering if i cn just hook to the ecu some where unless you guys know what wire to hook it too. also i have to hook up one wire to the ignition switch to the on position well does anyone know what wire that is on the swith or is there a easier way to do this please hlp guys
Old Apr 23, 2005 | 11:02 PM
Myszkewicz's Avatar
Try the tach signal wire (87 Green/white - Tachometer signal from the link in my sig) for the tach.
For the ignition switch, you just need a switched power source? There's a few open spots in the fuse block that are switched on by the ignition. Try here, the red wire (which powers my radar detector) comes on when the key's in ACC or ON.
Old Apr 24, 2005 | 07:51 AM
lucky04's Avatar
omg i should give you money for this. that was prolly the most helpful reply i have ever gotten onn this forum thanks man
Old Apr 24, 2005 | 08:52 AM
Myszkewicz's Avatar
What was I thinking? I meant to say "Search, Newbie".
Old Apr 24, 2005 | 08:56 AM
lucky04's Avatar
ok tahts more like it thanks
lucky04's Avatar
hey one more thing is the ecu kinda behind the glove box but under the dash with all the wires facing down
Old Apr 24, 2005 | 12:33 PM
Myszkewicz's Avatar
Yes.
nor11384
AEM EMS
Apr 25, 2015 06:00 PM
familymr
Aug 1, 2014 05:26 AM
lockadam2112
Dec 24, 2007 04:15 PM
Tyrade
Sep 8, 2006 07:05 AM
JWERNER24
Feb 1, 2004 07:54 PM
