Simple Question About Painting Break Calipers
Old Jun 24, 2005 | 09:47 AM
RalliTrav05's Avatar
When painting your break calipers, is it necessary to use primer first? Also, approx. how many coats are needed on each caliper for it to look its best?
thanks
Old Jun 24, 2005 | 09:55 AM
20psi's Avatar
its brake not break and you can get specific caliper paint at walmart, pepboys a&a....etc..
Old Jun 24, 2005 | 09:57 AM
RAMTL05's Avatar
I was wondering the same thing, but also, any recommendations on the type of paint to use? To get a nice gloss do you need the primer or just a certain kind of paint?
EDIT: I guess that was answered
Old Jun 24, 2005 | 10:09 AM
Regnout's Avatar
My buddy painted his Subaru 2.5RS calipers. It looks really good. He used the kit from dupli-color and just follow the instruction on it. If I remember correctly, he used a wire brush to get all the loose metal off the calipers and painted 2 coats. No primer or anything. I have pics at home if you guys want to see it.
Old Jun 24, 2005 | 10:24 AM
Walbomb's Avatar
That's pretty much what my kit said to do. It's a ceramic paint kit I got from Canadian Tire here in town. Clean calipers with wire brush, clean calipers with kit's cleaning solution, apply paint as many coats until satisfied.
Old Jun 24, 2005 | 10:32 AM
mojambo's Avatar
I did the duplicolor, black. I did 2 coats before winter and it saved my calipers drom rust. I did an other coat this summer and their great. WHen the brakes get hot the ceramic paint bakes on. Great bang for the buck
Old Jun 24, 2005 | 11:14 AM
shiroboi's Avatar
Heh, I did mine ghetto style, While I was rotating tires, I masked the rotor off with newspaper and hit it with thee coats of gloss red krylon. They look great though. I've only gotten a little paint flake. So my advice, dont think to much about it. If they have high temperature brake paint, I'd probably use that.
Old Jun 24, 2005 | 11:23 AM
EvoDreamz's Avatar
i used the duplicolor kit as well... basically that kit can cover like 5 cars lol
so surprising.... since my friend bought it and painted like 3 coats each then gave it to another guy 3 coats each and then to me and again 3 coats.... and the thing is still like half full
so its best to just get a group of ppl and chip in for that 1 kit
Old Jun 24, 2005 | 11:46 AM
Azure's Avatar
Exactly true - any small imperfections that come up with my paint, hell, I still have 3/4 the can left...
Old Jun 24, 2005 | 12:07 PM
Daddymac's Avatar
Is it a spray or brush? I presume for best results you should take the caliper off. But its not required right?
Old Jun 24, 2005 | 12:08 PM
EvoDreamz's Avatar
the kit is just brushed on... i just left the calipers on and brushed in the correct areas... the paint doesn't drip ne ways so its perfect in my opinion
Old Jun 24, 2005 | 12:58 PM
RottyM's Avatar
I used the Caliper kit paint from duplicolor too... its the best way to go..... and it does drip if you arent careful... thing to keep in mind are take your time to do it right.. let the paint dry a bit between coats, and when you put your wheels back on. I havent had any chips in the paint whatsoever... its perfect.
Old Jun 24, 2005 | 02:02 PM
aflancerdude's Avatar
I cant wait to do this.
Just gotta decide on a color.
Hmmmm.
Old Jun 24, 2005 | 02:53 PM
Myszkewicz's Avatar
I used the black Duplicolor kit, and I'm pretty happy with the results. I put three coats on the front calipers, haven't done the back ones yet. Maybe tomorrow.
Old Jun 24, 2005 | 02:58 PM
the-kid's Avatar
This is on one of my next to do's......can I see a picture of one done?
