Rt Axle CV BOOT Leaking
Old Aug 1, 2005 | 07:09 PM
RAKenzo's Avatar
Exclamation Rt Axle CV BOOT Leaking
Ok, so I come home from a road trip and i'm 400 miles over my oil change. Don't think it has anything to do with this, but i just state it. Anyways I look at the bottom of my garage and I noticed some thick black oil. I thought maybe I ran over some tar or some crap. I take it into the dealership for an oil change and ask the guys there what the black oil is. Turns out its my Right Axle CV Boot Leaking. I don't know much about this and wonder how serious it is. Thankfully my warrenty covers it, but the parts won't come in till next week. Will it be safe to drive on? And wth is this anyways??? Thanks
Old Aug 1, 2005 | 07:17 PM
BLKRalliArt04's Avatar
You should be alright from the sounds of it. If you can still turn your car with little force you should be fine. But yeah get it done ASAP.
Old Aug 1, 2005 | 07:23 PM
RAKenzo's Avatar
Alright thanks man. There is one thing though. I seem to hear a "clunking" noise, and I think it's comming from my brakes. Maybe the suspension, I don't know. Anyways, it only happens when I apply the breaks, or turn to much. Do you think it has to do with this problem??
Old Aug 1, 2005 | 07:24 PM
I doubt it, i wouldnt worry because the mechanic there woulda said something if he thought your car was unsafe to drive. Unless he was a careless ***** of course.
Old Aug 1, 2005 | 07:25 PM
OC_Ralliart's Avatar
i have the same problem with the clunkin sound but only when i back up every now and then.
RAKenzo's Avatar
Alright, well the part is comming in a week, and i'll update then. Thanks for the help BLKRalliArt04
No I only get the clunking noise going forward. Atleast I think I do. I'll listen for it going backwards tomorrow.
Old Aug 1, 2005 | 07:35 PM
wrecked's Avatar
A clunk like that could very well be a bad CV joint, which your boot is covering. If you lost the grease in there, and got a bunch of grime in there, it could be on its way to failing. I would definately talk to them about it... you may end up getting a new CV joint aswell. A bad CV joint will typically clunk going around a corner... some going forward, some in reverse.
Old Aug 1, 2005 | 08:12 PM
Myszkewicz's Avatar
It's safe to drive on for a week, for sure. My neighbor's kid has been driving with a torn boot for at least a year. His CV joint made clicking noises at first when turning, but it's getting pretty bad now. I've got a used axle for him (his car is similar to my old ones), but he's too lazy to put it in.
Old Aug 1, 2005 | 09:05 PM
WoRkZ's Avatar
Post
Just so everybody knows...
Some of the guys might also have the same problem I'va had (and a very small number of other owners). Mitsubishi got a batch of weak springs from their supplier and if one got installed on your car, it would eventually collapse a bit (mine was collapsed about 1/2"). I whish they'd use something alse than the word collapsed to describe it though... it sounds like a catastrophe while infact, the car drives okay (you just can't notice it). Only a clunking sound through the chassis tells you that something might not be perfect.
Of course, there is no danger to the car or the people who ride in it. And this is all covered by the waranty. This is not the most common of problems either and I haven't of any other car being affected but the RA (our springs have a very specific compression ratio and we don't share these parts with other Lancers).
Old Aug 1, 2005 | 10:17 PM
reTro's Avatar
So basically, you got a FREE 1/2" lowering kit from the dealer? LUCKY!!!
Old Aug 1, 2005 | 10:20 PM
lookslikeanevo's Avatar
go and get it covered from the dealer
Old Aug 1, 2005 | 10:24 PM
ProjectR#69's Avatar
That sucks!!! It is a good thing that you are under warranty. I had one of my strut bolts pop out while I was driving and I had to have it towed. The tow truck driver messed it up when he put it on the flat bed. He poped the axle out of its joint. Lucky for me the CV boot wasnt damaged. I was able to pop it back in, put some more grease in the joint and replace the lock ring. No problems ever since then (knock on wood). That was about two months ago.
Old Aug 1, 2005 | 10:52 PM
Myszkewicz's Avatar
Yeah, on one wheel.
Old Aug 2, 2005 | 05:40 AM
WoRkZ's Avatar
Talking
Yeah... if only they could have made the other spring the same height.
I saw a tuner show on TV the other day and the guy didn't like the ride height so he took the front springs off, cut them to the desired lenght and put them back on. If only real life were that simple...
Sorry for the OT...
Old Aug 2, 2005 | 03:46 PM
bruce988jl's Avatar
hm... i had clunking sounds coming from my car when turning, they replaced the outter tie rod, didn't work then they're replacing the inner tie rod. if that doesn't work then they're replacing the entire steering rack or something like that... but i'll keep an eye out for that 1/2 inch drop
