Quick Question For Those With The High Wing...
Old Aug 30, 2005 | 09:51 PM
Arithmetic's Avatar
Exclamation Quick Question For Those With The High Wing...
... does the OEM Evolution 8 (High Wing) Spoiler fit the ralliart trunk holes exactly, or am I gonna need to do some drilling?
Thanks.
MODS, please lock after a valid response... i don't wont this thread to turn into a flame fest.
P.S. I did a search, couldn't find an exact answer to the question.
Old Aug 30, 2005 | 10:25 PM
waxwozax's Avatar
you will have to drill 2 new holes , which is not a big deal ..... the high spoiler will be hiding the 2 holes that wont b e used
Old Aug 30, 2005 | 10:27 PM
lookslikeanevo's Avatar
then why IS the RA wing a direct bolt on? to the evo trunk?
Old Aug 30, 2005 | 10:42 PM
Arithmetic's Avatar
Exclamation
^^^ good question rigo, that is true.
Can anybody answer?
P.S. Rigo, you got a PM.
Old Aug 30, 2005 | 10:45 PM
^no i dont have a PM
Old Aug 30, 2005 | 10:46 PM
ok now i do
Old Aug 30, 2005 | 11:05 PM
bruce988jl's Avatar
haha, yea if the holes line up fine with the RA to a Evo trunk, then the Evo spoiler should line up fine with a RA trunk... But from what i hear that's not right, i'm not sure about the RA on the evo, but with the evo on the RA some drilling is required... which is the main reason why i didn't get it because i might want to switch back...
Old Aug 31, 2005 | 05:22 AM
ddcha's Avatar
AND THE ANSWER IS....
The Evo spoiler needs 3 holes on each side (left and right). The RA spoiler only uses 2 holes on each side.
If you put the RA spoiler on the Evo, it's a direct fit, but one of the holes doesn't get used.
If you put the Evo spoiler on the RA, you need to drill a 3rd hole on each side.
GET IT?
Old Aug 31, 2005 | 07:00 AM
AlkalineTrio124's Avatar
^That's not right... If we're talking about a spoiler off of an Evo, or directly from Mitsu... I don't know about the a/m replicas, though
I have a spoiler off the MR...
You need to drill 2 holes towards the front of the trunk...
If you open the trunk & look at the underside... There's those rubber spacers that you can change the height of to change the clearance of those...
You can take those completely out...
If you do you will then see where the holes will go for the Evo wing to fit...
Old Aug 31, 2005 | 07:42 AM
ddcha's Avatar
I was talking about the replicas. not the direct OEM. hope that clarifies...
Old Aug 31, 2005 | 08:07 AM
Arithmetic's Avatar
Exclamation
Thank you.
I didn't really understand your install, I bolded what I didn't quite catch.
Old Aug 31, 2005 | 08:18 AM
waxwozax's Avatar
the replica and oem wings requires the same holes to be drilled ......... trust me
Old Aug 31, 2005 | 08:44 AM
ddcha's Avatar
Then I don't know what I'm talking about. I'm just sharing what the manufacturer of the replica told me when I was considering the Evo 8 replica wing.
Old Aug 31, 2005 | 09:22 AM
Originally Posted by Arithmetic
Thank you.
Sorry if this isn't clear...
If you open your trunk all the way... Look in front of you & you'll be looking at the underside of the trunk lid on what the spoiler rests on...
There's a rubber piece that's like a stopper for the trunk... One on each side...
If you take those out then you can see where the front screws will go/holes will need to be drilled for the wing...
