First mod?
Old Sep 5, 2005 | 02:35 PM
05 Silver RA's Avatar
I was thinking about the RoadRace Progress spring kit, the TEIN coilovers are just a bit too pricey right now. is there something in between? also, with the spring kit, is camber enough of an issue to require a camber kit? the last thing i want is to eat my tires up.
So, an axleback would simply be for sound, no real performance gains? i can't really do the downpipe mod, unless I come up with a CEL eliminator, have to be tested annually here. plus i don't really want to stare at that light either.
JJ
Old Sep 5, 2005 | 03:01 PM
otter's Avatar
EvoM Administrator
JJ
Camber is not an issue with the Progress springs. The drop is also minimal enough to not affect your strut life too much.
There's an easy CEL fix for the downpipe that works.
https://www.evolutionm.net/forums/sh...ad.php?t=99137
I did this fix at 6,000 miles. I'm now at 18k miles and no CEL yet.
Old Sep 5, 2005 | 03:15 PM
CF-Ninja's Avatar
you could always just take the bulb out of the cluster for the CEL. My brother did it on his OZ
Old Sep 5, 2005 | 03:44 PM
yeah, but as a former emissions inspector in GA, i know that won't pass. two reasons: GA does a CEL function check at KOEO, and when they connect the OBDII scanner to the car it'll also pull the trouble code.
Jake
Old Sep 6, 2005 | 05:39 AM
ThyPunko_PR's Avatar
For my....go first for the Progress Sway bar/perches...(it is a mod that you can "feel" right away after install)....then you can go for the CAI or a Works/K&N high flow filter (I got the K&N). After that change your oil to syntetic and get better tire/wheels. Also the short shifter kit is a must for the 5spd if you have one.
Old Sep 6, 2005 | 05:55 AM
WoRkZ's Avatar
Lightbulb
My take on it:
1- Quality tires
2- Joe's EVO 8 pulley (standalone mod, instant gratification )
3- Intake
4- Exhaust
5- Lower tie bar and then the rest...
6- Piggyback ECU
Old Sep 6, 2005 | 08:01 AM
AlkalineTrio124's Avatar
TIRES! Our stock ones are crap... Even if you want to keep your stock rims and not spend the $$$ on a/m rims, get new tires!!!
Old Sep 6, 2005 | 08:08 AM
WoRkZ's Avatar
Thumbs up Your right of course...
I stand corrected... your right on tires having to come first. I tend to forget about that... I bought the Pirelli's with the car. I must say that lately it makes an even greater difference since I found the best pressures for them (35 front and 33 rear for me).
Old Sep 6, 2005 | 08:37 AM
Ralliartist's Avatar
Tires are a good idea.
Old Sep 6, 2005 | 10:13 PM
captain150's Avatar
It's time for me to start modifying my RA, but i'm curious where to start. what would be your suggestions for a first mod?
I'm thinking cool-air intake/SRI and probably a catback or axleback exhaust.
J
What kind of things are you looking for? SRI is a good cheap first mod. If you want something really noticeable, get RRM/Progress's rear sway bar and perches. They tighten up the back end A LOT. Easy to install too.
Old Sep 7, 2005 | 03:11 PM
so it looks like the plan will be:
#1 rear sway bar and perches from RRM
#2 Injen CAI/SRI combo intake.
#3 3" exhaust with at least a 6" tip, gotta have the flow and sound!
#4 Stickers
#5 neon
ok, so the last three are jokes...
I don't want to buy tires right now, i just can't stomach ditching four tires with good tread... maybe when these wear out
Old Sep 7, 2005 | 03:31 PM
Yelliart04's Avatar
I feel the same way about ditching new tires. I want use the stock tires as a winter set and get some high performance summer tires but I have nowhere to store them. Oh well winter's coming up anyway.
Old Sep 12, 2005 | 09:42 AM
aflancerdude's Avatar
yeh im mad cuz i ditched my new tires and rims for something new and forgot to go back to the shop to get my stock rims and tires
damn that sucks.... those were gonna be my winter tires..
Old Sep 12, 2005 | 09:48 AM
psychlancer's Avatar
the original stock tires that come on the car are not a good choice for winter tires. It took me one day of driving on them in the winter to decide I needed an actual winter tire. Spend money on proper tires or you'll end up spending more money fixing your car when it slides into things.
Old Sep 12, 2005 | 09:52 AM
WoRkZ's Avatar
Post
^ +1
