opinion on gtech pro kits
ok in my september issue of sport compact car, page 145, i see an add for gtech pro. www.gtechpro.com/co ... it says it mesures 60ft time, 1/8 1/4 mi time, hp and tq, rpm and shiftlight......
well heres my question,, will this work for our car, will it be accurate, and how do u guys feel about this?
thanks
thanks
I have one, and I like it, but I don't get the use out of it. It will work, but the rpms don't work all the time. It gets the readings out of the cigarette lighter from the alternator current. Even without the readings there, it still works fine. The only thing that affects is the shiftlights. Most of the features on it are started and ended by a button push or g's from your cars movement. I am interested in selling mine if you like, pm me. I have the pro rr, and all the accessories with it.
I thought that JOE'SEVO8 said that the underdrive pulley didn't affect your alternator current though. Even still, you don't have to have the RPM's to use the unit. Everything with the exception of the Shift lights works on g's, and the unit is extremely sensitive. It's a good unit for testing mods and whatnot, it will give you your readings minus every environmental reduction there can be during driving. The website does state that the RPM's are not guaranteed to work on every car out there. That's trial and error, but all you need the cigarette lighter for, if it doesn't read rpm's, is power. Everything else is stop or go or a push of the ok button.
Well, lets think about this. I've stated in a previous thread that JOES UD pulley DOES effect the alternator output buy about 2.15 volts. I have a VOLT meter that was reading 14.4 ALL the time (the thing NEVER used to move) and now w/ the UD pulled it will dip as low as 11.9 depending on what acc. are on.
So, if the Gtech takes readings from the cig lighter then how accurate could it be considering the reading WILL fluctuate (due to the voltage spike as the rpms raise) from idle to even 1000 rpm's.
Anybody have more info on these?
Everyone here keeps talking about that RPMS, but that is the least of your worries when you have the gtech, it doesn't need them to do anything except shift lights. The unit itself is very cool, it will give you horsepower and torque ratings, 1/4 mile times etc. Then it has the road race mode, which records you lateral movements to tell you how hard you are driving and see where you could push more.
i would buy this but the UD pulley thing is making it iffy... when u hooked it up to a stock ralliart, what was your weight you typed in? and what was stock hp on it? thanks
I typed in the gross vehicle weight plus my weight, and for horsepower I used 163, at the time I had sri and catback. I don't know for sure what the stock hp on it was, but when you do a run, your hp varies to driving conditions. You have to remember that there are many different factors in street driving that could change the output of the unit: Wind, Slope, Friction, etc....., It's not a mobile dyno, but if you use the same testing conditions, it can be very effective. As for the UD pulley, that will not throw off any readings the unit gives you, the only thing that the UD pulley will affect is the shiftlight/rpm readings. If you wanted it for that though, you should just buy a tach.
