My RA is shaking like a earthquake!!!
Old Nov 26, 2005 | 09:31 AM
Master_French's Avatar
Sup! Yesterday, i took my RA for a drive and damn the all car was shaking very very very bad.... I stopped to see if they were some snow stock on the tires but i see nothing. My friend told me its because i do some handbrake and they is some snow stock somewhere... Any info plz cauz i'm a little worry about it.
Old Nov 26, 2005 | 09:53 AM
otter's Avatar
EvoM Administrator
Get underneath your car and check behind all your wheels. If you have a garage, or access to one, park your car in it and let it thaw. If that doesn't do it, then you might need to have your wheels rebalanced.
Old Nov 26, 2005 | 09:57 AM
EvosLilBro's Avatar
first step should be learning where the O and U buttons are on your keyboard
Old Nov 26, 2005 | 10:03 AM
EvoLite's Avatar
Your car won't shake that bad just from wheel balancing. You'd only notice that over 80 KMH. Did you have winter rims put on recently? I just had my stock rim and tires put on recently for winter and the car shook violently after they were done. I brought it back and found out they left the spacers on from my summer rims without realizing it. They took them off and everything was fine.
Old Nov 26, 2005 | 10:20 AM
FAV's Avatar
FAV
I disagree, if two of your four tires are out by 2.00 or more, it would cause that kind of shaking, or if they were out of alignment, (although tire wear would be a bigger problem with the alignment). but agree with otter go thaw out, see what happens.
Old Nov 26, 2005 | 10:25 AM
Myszkewicz's Avatar
It *can* if someone took the balancing weight off and put it back on opposite where it was.
Old Nov 26, 2005 | 10:32 AM
Yeah it only shake over 80 KMH... I put my winter rims like 2 or 3 weeks ago but i had them last years and it never do that before...
EDIT: also, last year my winter tires were put by a shop but this year i put them myself but i don't understand why it suddently shake like this.
Old Nov 26, 2005 | 10:39 AM
Probably the most usefull anwser ever dude. English is my second language so i know they are some mystakes in my sentences but at least people can understand me. I bet i'm better in english that you are in french.
Old Nov 26, 2005 | 11:08 AM
jackass's Avatar
take your car to a carwash.
ive had some nice hidden ice before and had the same problem. hot water will take care of any ice buildup. if it still shakes after that then you may just need a balance
Old Nov 26, 2005 | 11:44 AM
I just took my car to the car wash and it doesnt shake no more! I had enought ice on there to build a castle... thk you!
Old Nov 26, 2005 | 02:22 PM
jackass's Avatar
good to hear it was only ice. its crazy how much a little bit of ice will make you shake like mad.
Old Nov 29, 2005 | 03:46 PM
05ES's Avatar
glad you found the problem man. Always nice to hear happy endings
akride907
Mar 17, 2016 02:13 PM
rzrxn
Nov 22, 2013 07:31 AM
digdat
Lancer Troubleshooting
41
May 28, 2012 10:57 PM
lbegorre
Oct 11, 2011 07:40 AM
Koroshiya
Nov 12, 2008 10:00 PM
