Oil change question
Old Apr 14, 2006 | 02:44 PM
redboy's Avatar
Oil change question
This may be a dumb question but I recently switched to synthetic and I always do my own oil changes. Before switching to synthetic, I always changed the filter and the oil at the same time. Now, I'm planning to change my oil every 10K and my oil filter every 5k. My question is if I remove the oil filter, will all the oil leak out.
Old Apr 14, 2006 | 03:26 PM
olschool's Avatar
Yeah, since your filter is "filtering" the oil, whatever's inside the filter will spill out.
Old Apr 14, 2006 | 05:12 PM
lanzerralliart's Avatar
EvoM Super Moderator
A Performance Difference Would Be Noticed If Your Wanting To Do Changes At The 10k Mark ... The Engine Could Handle It But It Like The Fact That You Could Live For Two Weeks Or More W/o Food But Do You ? And Would You Want To?
Old Apr 14, 2006 | 05:50 PM
otter's Avatar
EvoM Administrator
Erm, I'm pretty sure you're incorrect. Where are you getting that info from?
Old Apr 14, 2006 | 06:25 PM
snowey1's Avatar
To answer your question, if you change the filter and not drain the oil; no not all the oil will come out. Just the oil in the filter and maybe a little more may drain out. Just fill your new filter 3/4 way up with new oil and install and check the dip stick to top off. I do the same thing with Mobil1, at half life I change the filter.
Old Apr 14, 2006 | 06:39 PM
evo8rcr's Avatar
I was gonna keep my flaming out of this thread but....................................
wtf are you serious first of all newb I would be scared to let you come within 100 miles of my car.
2nd you can't change the filter without the oil without making a big *** mess plus losing half your oil gimme a break
3rd 10k miles between oil changes your f'n crazy even if it is syn 3k is recommended maybe push 4k if your broke 5k and that extended oil by "Q" crap is a waste
also you should probably use a syn blend it's cheaper and does the same thing if you had an evo or f/i go witha full syn but since your in a ra n/a syn blend would be fine
Old Apr 14, 2006 | 07:00 PM
Joe Spingler's Avatar
Oil topics bring a multitude of opinions.
For all the oil related information you could ever want, visit the forums at bobistheoilguy.com
My personal take is to run the full recommended 7500 mile interval if running synthetic, unless your Ralliart is a taxi cab or the odometer increases 1/4 mile at a time.
Running syn for only 3K is a complete waste of money and quality oil.
Old Apr 14, 2006 | 08:48 PM
amax's Avatar
He said ...every 10k, 5k - He's Canadian - that means 10,000 kms, and 5000 kms - the k being for kilometers. Equates to about 6000 miles and 3000 miles.
Old Apr 14, 2006 | 09:01 PM
Khobin~'s Avatar
Perhaps another thought, if you plan to use syn. oil for 10k, why not use a syn. oil filter that will also last for 10k? Yes such filters do exist, they're a couple $ more then a regular filter (just like syn. vs reg. oil) but hey, saves on hassle by doubling the change intervals. Just check it regularly, like you should be doing anyways and it should all be good.
Personally I've never understood the idea of draining the oil, putting on a new filter, then dumping the dirty/old oil back in the engine, even if it is technically still good for another 5k.
And hey, can't void the warranty because it's actually rated to 10-11 k.
Side Note: In my warranty/service manual it actually says to change the oil every 6000kms(assuming regular oil), I always thought 5000kms was the proper interval, and so found that a little funny.
Old Apr 14, 2006 | 09:15 PM
Pikachu's Avatar
I would prefer that the change be made at 8K rather than a 5K-10K thingy.
Old Apr 14, 2006 | 09:32 PM
Ralli04Art's Avatar
our cars DO NOT come with synthetic stock. the only car that deos is the evo.
Old Apr 14, 2006 | 10:15 PM
redboy's Avatar
Thats what I thought. Thanks for your help snowey1.
Sorry guys, I was talking kilometers when I said 5k & 10K.
Old Apr 15, 2006 | 06:03 AM
If your dealing with kilometers, many premium filters will go 10K easily. For about $5 Purolator PureOne, Napa Gold, and Wix come right to mind. Mobil 1's and K&N's are about double the price, and don't provide better filtration or flow going that distance.
Seriously, check out bobistheoilguy.com. Those guys are absolutely nuts about their oils, and everything oil related.
Old Apr 15, 2006 | 06:34 AM
snowey1's Avatar
[QUOTE=Joe Spingler]Oil topics bring a multitude of opinions.
Yes, you are correct. Opinions are like *** holes everyone has one, some are just bigger than others, I read what Evo8rcr's wrote, his must be pretty big.
Old Apr 15, 2006 | 05:58 PM
Sorry About The Confusion My Friend With An Evo Said That The Ra's And The Eclipse's Come With Full Synthetic Stock My Mistake For Listening To Him Sorry Again You Live And Learn ....but Hey I Wouldn't Hold The Whole ''newbie'' Thing Against Anyone Just B/c They Or I Am New To This Forum Doesn't Mean I Or We Are New To The Game ....
