1/4 mile time?
1/4 mile time?
Im going at the ROCK sometime in may i think the 13th and going to run my car, can anybody give me some tips on how to bust low 15's I got an Injen intake
SOME THINGS IM LOOKING FOR?
-Should i take the spare tire out and the jack
-Should I take out anything else or do anything else
-Tire pressure?
-Launching 3K?
And anything else????
-Tire pressure?
-Launching 3K?
The Less Weight The Better,tire Pressure Is Is Good Around 16-20psi ,just Be Sure To Warm Up Those Tires,launching At 3 Should Be Good Just Don't Floor It If You Do You'll Burn Up Though The Gears And Have No Traction ....result, Not The Time You Wanted.....take Some Time And Get Use To The Track Practice Makes Perfect.... Don't Expect Your Dream Time The First Run You'll Be Disappointed... Good Luck.....
OK i did 16.2 yesterday with all my tools and a box of motor oil in the trunk. My car is tottally stock and tere was no grip in the track at all, so u should not have any problems hitting 15.
Actually im prepping for a match with a 2006 Civic SI tonight at hte track. wish me luck
PS. i tried to post the time slip but couldnt find a way to do it
good luck hitting the 15's
Originally Posted by Lancer7
My best was 15.07. But I'm stuck in 16's now since I stretched the synchro for 3rd.
Drive quick but be gentle or it'll be your last good run till you fix what you broke.
Mike
ok things u can do...
a)remove everything from your trunk including the subwoofer (if available)
b)empty your tires a little (not much because u might loose momentum)
c) personally i believe that 3k launch is too high i recomend 2.5k rpm for launch
verify track conditions and if they sprayed bite or something to make it sticky
my best time is 16.04 100% stock in a very humid night so u must do 15's
the best of lucks.
BTW my thread was locked so im going to say it here for those interested last night the civic was faster but i crossed the finish line first. any doubts i have the time slip. I said the guy was not a very good driver
another one for mitsu
the best of lucks.
Originally Posted by matute
nice time what do u have in your car???
That is my unofficial time measured with a Beltronics FX3. It's very accurate, but obvoiusly you won't have a reation time.
Originally Posted by MikeDVB
Stretched the synchro for 3rd... what do you mean, how exactly did you do that and how can you tell.
Mike
Mike
Originally Posted by MITSU-DEALER
I found this timeslip, I find it amazing not for the time but for the beaten Audi TT
but nice times for you 60ft @ 2.3sec, 600ft @ 9.5sec, 15.5 sec and 88mph
my best so far is 60ft @ 2.2sec 660ft @ 10.1sec, 15.7sec and 87mph
hopefully mine will change by next weekend
My best right now is 15.1 at 92 @ a humid night and non sticky track
Im trying the other track since its way stickier and all the cars always better their time at least by .3 or so. Salinas to the PR folk
