Anyone's CAI do this?
Old May 3, 2006 | 09:07 PM
DangerousDan's Avatar
Originally Posted by otter
Doesn't help that our engines move so damn much. I'm positive that the only reason mine hasn't broken is because the AEM bypass I put in allows some flex.
My friend has a civic with an aem intake. until recently he also had the bypass valve. The valve split in two pieces, so make sure you check it periodically. I am beginning to think that the bypass valve is a good idea at all.
aem says its purpose is to prevent hydrolock when the intake inlet is completely submersed. The is a definite sound difference, and probably a little power difference, with the bypass valve installed. I have seen one break.
Unless you are driving through deep *** puddles you don't need this, and if you have it you had better keep an eye on it.
Old May 3, 2006 | 09:19 PM
NonEvo's Avatar
Originally Posted by amg_dragon
Now I realize that the engine moves quite a bit stock. You have to be freaking kidding me to say THAT is the reason this CAI broke! I'll accept material defect from Injen as a possibility but where is the missing piece? That piece not only broke the welds but tore the metal... I went "off roading" into a concrete barrier and bent/broke inner tie rods and lower control arm and didn't generate enough force to break my Injen CAI. So I'm more than a little curious to hear what your car has been doing! I'm guessing a little something more forcefull than "revving it up at a stoplight". If not then I would DEMAND a refund or replacement from them.
I can honestly say that I am relatively easy on my car. Never Raced, and only driven hard on occasion. 99% of the time my car is only used for transportation from my house to work, which is about 15 minutes mostly highway. I did purchase the intake used off this site, but it appeared 100% fine when I put it on.
Old May 4, 2006 | 01:27 AM
amg_dragon's Avatar
My money is on a material defect or the previous owner being unreasonably harsh on their car. My car is a commuter but there's plenty of stoplights, on ramps and hapless speedbumps in training to drive around on the way to work. Anyways, my point being that I'm not "soft" on my CAI and I've never seen so much as a stress crack around the welds or any damage to the metal around the weld. You should seriously contact INJEN about it and raise your concerns about potential engine damage resulting in a piece of their product trying to enter your engine.... or something similar to get them off the high horse and into a placating mode. I can't locate my warantee card so I'm not positive about it being a 90day or limited lifetime warranty. Acording to Injen's website it's a limited lifetime warranty. Worst case senario, buy a new one or find someone local that just bought one and trade it in for a replacement.
Old May 4, 2006 | 07:57 AM
otter's Avatar
EvoM Administrator
I check it regularly, as I'm aware of them being prone to breaking. It's a necessity during the winter/spring months in Michigan. Combination of tons of rainfall, and crappy roads with lots of low spots, means it's not uncommon to hit puddles that are over a foot deep.
Old May 4, 2006 | 08:57 AM
ROCK's Avatar
You are both right. ENgine moves a lot more than you think. With an intake that does not have at least 3 inches of flex (rubber) they will break. Being aluminum, those AEM and Injens are like tin cans. They get worked back and forth until they tear next to the weld. Like pulling the opening tap on a coke can!
ROAD/RACE
Old Aug 20, 2007 | 07:32 PM
taka's Avatar
My Cai is broked, I'm from Quebec, soo what can I do ??
Old Aug 20, 2007 | 10:16 PM
ROCK's Avatar
Our intake? What broke? Doubt it is ours.
ROAD/RACE
Old Aug 21, 2007 | 01:28 AM
GearDownSon's Avatar
ROAD/RACE
So vain
Old Aug 21, 2007 | 05:47 AM
taka's Avatar
Thumbs down
No fortunately it's not RRM's one...
I have Injen CAI ! !!
I'm soo MAD
Old Aug 21, 2007 | 07:19 AM
gjgfrombigd's Avatar
So are RRM's motormounts the answer to this problem?
Old Aug 21, 2007 | 08:13 AM
otter's Avatar
EvoM Administrator
Yes.
Old Aug 21, 2007 | 08:44 AM
ROCK's Avatar
I just know we have virtually 100% reliable intakes. INJEN and AEMs seem to break the most.
ROAD/RACE
Old Aug 21, 2007 | 09:44 AM
migs647's Avatar
Wow, I'm sold... I'll take RRMs. Besides the fact that they are cheaper, why would you trust anyone else besides the lancer experts? Now I'm just debating if I should get a by-pass valve or not. I had no idea the by-pass valves broke!!! Plus i'm sure Rock wouldn't be too happy with me cutting their intake in half to install a by-pass valve :-p
Old Aug 21, 2007 | 12:38 PM
Just get the AEM/INJEN and get RRM's motor mounts. That way you can install the bypass and have less movement from the block.
Old Aug 21, 2007 | 12:53 PM
the bypass valve will break, regardless of the mounts. they are flimsy and weak plastic pieces of junk. I would only install one if it was absolutely necessary where I lived, and I would make sure to check under the foam at every oil change to make sure there are no stress cracks forming.
