Kartboy EVO shifter bushings fit the Ralliart
#32
Originally Posted by r3z0nate
Does these even require any type of maintenance?
Also, had anyone had an issue of poping out of gears occasionally?
#33
oo no i bought the 2 sets of bushings... One goes into the shifter base INSIDE the cabin, and the others are the underhood ones that Joe's talking about... The ones that fit inside the cabin don't fit my shifter base (plastic white piece that supports the shifter assembly in the center console). But i'm sure the ones that go into the linkage underneath the hood of the car work fine, i'm just too lazy to install them right now...
#34
Originally Posted by ralliarts MVP
I think you might have a synchro issue there
#35
The ones inside your cabin are not designed to fit the hole itself. Rather install them line the screw up and bolt it down. You will flex the poly when they are installed. They dont need to slide into the shifter base.
#36
#40
i've had my brass bushings installed both underhood and under plate for nearly two years, thru winters and everything, zero problem.
not sure why yours would seize into place.
