RA manual vs. auto
Old Jun 26, 2006 | 02:49 PM
redlancer14's Avatar
RA manual vs. auto
Does anyone know the policy on the 06 ra's? I got an auto because my job is alot of driving but im kinda regreting it! I have had it for about 2 weeks... Is there any way i can change the gears and what RPMs they shift at or do something becuase i do want to drop alot of money into this but i really dont know if its worth it! I wanted to drop a turbo kit, exhaust, intake, Header on it!! Please let me know.... Thanks (sorry for the noob posts)
Old Jun 26, 2006 | 03:34 PM
lanzerralliart's Avatar
EvoM Super Moderator
umm...i would do a tranny swap ,but in your situation i would try to understand my car better in that you can NOT have a turbo kit with intake and headers...but you did say you wanna put some money in the car so a tranny swap should be nothin for you..........
Old Jun 26, 2006 | 03:43 PM
Mitsubeastin's Avatar
i have a auto ra bcuz of a soccer injury but I love it im currently getting a transmission built to accomodate other mods
Old Jun 26, 2006 | 04:34 PM
Well isn't there chips that u can change wat ur A/T shifts at!? I mean i know there is a way you can make a A/T as powerful as M/T... Atleast i thought there was!! Also a tranny swap is really expensive.
Old Jun 27, 2006 | 05:46 AM
ralliart329's Avatar
i own an auto and kinda regreted it to until i started modding it. now i still kill the competition and have a comfy ride in 1 1/2 hrs of traffic to work. Get an intake and UD pulley and you'll be alot happier.
Old Jun 27, 2006 | 08:16 AM
otter's Avatar
EvoM Administrator
If you want firmer shifts you can get an aftermarket valve body for your AT. No idea if there's one out there or where you'd find it. Best bet would be to find out what past Mitsu used the same transmission and go from there. Other option is to upgrade your torque converter.
Old Jun 27, 2006 | 09:01 AM
no one answered me last i checked when i asked in another thread, what exactly a torque converter is and does? how much is an aftermarket? how much would i benefit?
Old Jun 27, 2006 | 03:04 PM
Nugordy's Avatar
I believe the auto transmission is the same as the ones that came in the later mirages. But I forget where I heard that, and I may be wrong.
Old Jun 27, 2006 | 03:31 PM
otter's Avatar
EvoM Administrator
A torque converter is a fluid clutch that sits between the engine and transmission. It's what allows your car to sit still, while in gear, without stalling.
http://auto.howstuffworks.com/torque-converter.htm
Upgrading it would help reduce powerloss and allow you to better put down higher power.
Old Jun 27, 2006 | 03:58 PM
not as expensive as a turbo kit ...when you said you wanted to put some money into the car what were you talkin about??? like a few hundred?? or a few thousand?? because if you wanna be up there you gotta get some sort of a list and stick to it......
Old Jun 27, 2006 | 04:20 PM
samj601's Avatar
do they make an aftermarket torque converter for RA?
Old Jun 27, 2006 | 07:40 PM
Nugordy's post may be a good place to start. b/c i don't think anyone makes one for the RA but if he's right the later mirages would fit i'd guess.
Old Jun 28, 2006 | 12:20 PM
Im looking to drop about 5k on my car... anyone got tips?
Old Jun 28, 2006 | 01:27 PM
either the RRM turbo kit or a whole bunch of mods like:
RRM UD pulley
Injen CAI
RRM Intake manifold
RRM header/diwnpipe combo
Highflow Cat
RRM exhaust
RRM sway bar and perches
RRM piggyback ecu
Slotted rotors
NEW TIRES!!! the ones on my 04 sucked
and lowering springs
i think thats like 3500-4000 in parts.
Old Jun 30, 2006 | 03:43 AM
kericr's Avatar
I did research on this a while back. Nobody makes a torque converter specifically for Lancers (RA or otherwise), but you still have a couple of options. Companies that specialize in Torque Converters (for example, www.tciauto.com) can rebuild your torque converter to a higher stall speed. I can't really tell you what kind of value you would get on this in either performance or price because I never got that far, I axed the idea when I found out I'd have to either send my TC in or take it to a shop where they could hold the car and test it with the converter.
A higher stall-speed torque converter is going to help you most in quarter-mile launches, because it'll let you crank the RPMs up higher on a power-launch then you could otherwise. I don't know what effects, if any, it has under rolling-launch conditions, where you can't power-launch, but I would venture to say that in that aspect, the upgrade is limited. I would highly reccomend you contact TCI Auto or a local transmission shop and ask them about this to see what kind of performance increase you can get out of a TC if you're really serious about it.
Oh and one more thing, a TC upgrade doesn't increase power, it's one of those more power to the ground upgrades.
