HIDS + Projectors
Old Sep 22, 2006 | 04:29 PM
Fifty's Avatar
HIDS + Projectors
Serached around but couldn't find any good info. Anyone with projectors that has installed an H3 HID into them can you please explain how you did it? I have the projectors and the HIDS but can not see a way to install the HID without splicing the wires.
Old Sep 26, 2006 | 10:12 AM
Racman709394's Avatar
are they bosch H3 projectors? or they are the ones from ebay?
the best i would recommend is to do a retro fit on the ebay projector headlgihts...
meaning....swapping HID projectors instead of those H3 projectors. here's the link to the completed retro fit on the ebay projectors https://www.evolutionm.net/forums/sh...&page=18&pp=15
i am currently doing another retro fit.....i am putting in E55 bi-xenon projectors....so i should be done this weekend.
Old Sep 26, 2006 | 10:24 AM
Fifty's Avatar
Thanks, I actually got this done two days ago with the help of a friend, but thanks for the link.
Old Sep 26, 2006 | 10:26 AM
vonzipper's Avatar
i want to do a retro fit on my projector headlights, but at the same time i want to change the halo ring to red. i would probabaly use just a regular red LED bulb. has any one done this on the fourm chagne there halo ring to a diffrent color.
Old Sep 26, 2006 | 01:07 PM
Fifty's Avatar
halo ring is easy to do (even I can do that) Streetconcept sells different coloured ones. All you need to do it open the housing take the wire that attaches the ring cut it pull out the halo ring ut the new one in and put the harness back together and done. That might not make sense as I typed it but once you open the headlight you'll understand what I mean.
Old Sep 27, 2006 | 10:42 AM
hey fifty, post up some pictures of your retrofit if u can. which projector did you use?
Old Sep 27, 2006 | 10:48 AM
Fifty's Avatar
It wasn't a retro fit (I'm too lazy for that) it was just a straight hid install into the regular projectors
Old Sep 30, 2006 | 09:40 AM
ahhh i see
Old Oct 28, 2006 | 03:30 PM
mtags24's Avatar
isn't it dangerous to put HID's in a non-hid projector? won't that spread too much light and blind people? how did it turn out?
Old Oct 28, 2006 | 10:26 PM
AdamRA's Avatar
Yes, I was going to do it until I saw a wall picture and the beams looked like ****...
Old Oct 29, 2006 | 01:00 PM
hm...to tell you guys the truth, those lens that you get from the ebay projectors are actually very clear (which is good) if you can, just mod it a bit such as.....the distance from the reflector bowl to the lens.. it will prolly be very nice projectors. but i would recommend changing the reflector bowl to the D2S ones. those works better since you mostly will be the factory BMW and the etc bulbs, which last longer.
Old Oct 30, 2006 | 10:42 AM
SlowRyd's Avatar
The clearness of the lens doesn't have anything to do with the projected beam. The most important thing missing from NON-HID projectors is the cutoff sheild. I have done a retro or two and would never use halogen projectors. If you are going to bother doing a retro, do it right. get a set of Xenon projectors, ballasts and a good damn wiring harness.
Old Oct 31, 2006 | 03:07 PM
eh...there is something call hybrid....there are some people who hybrid the 300Z projector lenses which are not HID, into a HID reflector bowl....and the outcome was super clear and wide....there is always little tricks to make it better.......and the clearness of the lens makes a difference.....read it up if u want....
