Mivec Controller
Old Nov 1, 2006 | 11:35 PM
RalliDew's Avatar
Mivec Controller
im told this will work for a mivec controller but its a bit pricy.
http://www.optionimports.com/gicavtaifuco.html
Old Nov 2, 2006 | 02:19 AM
reTro's Avatar
Hmmmm sounds interesting. I'd like my MIVEC to come on before I start boosting, say around 2,500 rpms.
Old Nov 2, 2006 | 05:42 AM
Lancer7's Avatar
I thought Mivec was a mechanical thing
Old Nov 2, 2006 | 06:31 AM
egk-69's Avatar
its mechanical, but who activates it, its the ECU
also about the guy who want it to kick in at 2,500, you first have to check, that the engine had the required OIL PSI to activate the mivec, because even if you send the signal to activates it , it wont activate till it had the required OIL PSI
just check out that first
Old Nov 2, 2006 | 09:57 AM
vonzipper's Avatar
whos going to be the first to try it?
Old Nov 2, 2006 | 10:29 AM
ralliart329's Avatar
360 is a little pricey to try it... even if i knew it would work i'm not sure if i'd want it that bad.
Old Nov 2, 2006 | 11:30 AM
EvoJutsu's Avatar
wat are the gains?? it prolly work really well with cams or bolt-ons
Old Nov 2, 2006 | 12:06 PM
DangerousDan's Avatar
that's backwards. the oil pressure tells the ecu to activate the mivec, not the other way around. the sensor that controls mivec is set to 45psi(iirc) oil pressure.
Old Nov 2, 2006 | 12:21 PM
I don't think their would be big peak gains, all low end, so you'd get to peak HP quicker. kind of like the gains the RRM piggy back gives.
This would be good for any car stock to heavy mod if it works well for mivec.
Old Nov 2, 2006 | 02:59 PM
egk-69's Avatar
i know, theres AN oil pressure sensor, that tells what the psi to the ECU, then the ECU decides to activate it or not (depending on the PSI)
what i mean was that the ecu activates it (to the guy who said "i think mivec was mechanical")
Old Nov 2, 2006 | 03:26 PM
CF-Ninja's Avatar
mmm bye bye gasoline
Old Nov 2, 2006 | 05:51 PM
RalliDew's Avatar
well iv found other ones that say mivec controller to for cheaper this was the one i was gettin wind of from other mivec forums.
S1monLM
Oct 5, 2006 02:37 AM
silex
Sep 5, 2006 10:55 PM
GgreyEVOIX
Mar 31, 2006 07:10 AM
johnjonfenomeno
13
Jun 22, 2005 11:13 AM
ralliartpr
Nov 11, 2004 10:40 PM
