Removing radiator
Removing radiator
Installing headers, can't remove that damn clip/plug that keeps the wires together on the radiator..
One of those plugs where you have to squeeze to get out..
Any tips?
KILLING ME
Any tips?
KILLING ME
don't use WD-40, go to the store and find Kroil or Liquid Wrench. You need a penatrating lube. I'd hold off on using an extension on your wrench. If they are rusted and you torque them to much they will snap. Then you will have a bigger problem on your hands. Heat them, and give them a little tap with a hammer. Not too hard cuz if you warp your threads you'll have another big problem.
You should not be having too much trouble because your car is almost new... but I did notice on a lot of the bolts on my car had a small amount of Locktite glue on them - so make sure you are using a quality socket so you don't round off the head on the bolts also you could give the head of bolt a small tap and see if it helps to loosen - but other than that elbow grease works very well... you are turning it the right way ?
Evoryder
Apr 29, 2019 10:09 AM
EvoDan2004
32
Mar 15, 2016 08:32 PM
Yakshii
12
Dec 27, 2009 05:32 PM
justchil
Dec 30, 2008 02:43 PM
fastassfourdoor
Mar 26, 2007 05:43 PM
