weakest part
Old Dec 5, 2006 | 10:46 PM
mitsumivec's Avatar
weakest part
so i was just wondering what the weakest part of our 4g69 motors is.. (reason i'm asking is what would happened if you upped the psi of a turbo.. what is going to be the first part to give out..)
Old Dec 7, 2006 | 05:49 PM
CF-Ninja's Avatar
Rods, pistons, combo of both... How much PSI are we talking here?
Old Dec 7, 2006 | 07:11 PM
otter's Avatar
EvoM Administrator
Headgasket is probably a weak point, too. ARP headstuds would help with this.
Old Dec 7, 2006 | 08:55 PM
Myszkewicz's Avatar
My money's on the headgasket, too. With ARP head studs, I'd say connecting rods.
Like CF-N asked, how much boost?
Old Dec 7, 2006 | 09:55 PM
mitsumivec's Avatar
well no more than 10 lbs. i was just wondering what would give out first if i were to raise it a couple with 91 pump gas..
Old Dec 7, 2006 | 10:10 PM
captain150's Avatar
My guess is you're fine up to about 12psi or so. IIRC, the rods in the 4G69 are even stronger than in the 4G64.
Old Dec 7, 2006 | 10:18 PM
otter's Avatar
EvoM Administrator
10 lbs you should be fine on stock internals, just get your fuel figured out. If you're paranoid, then headstuds.
Old Dec 8, 2006 | 07:46 AM
mitsumivec's Avatar
hmm. so changing out the headstuds i should be fine with 91 pump and 10 lbs?
Old Dec 8, 2006 | 10:14 AM
RAPPER8521's Avatar
MITSUMIVEC, With all that in mind, especially with the mivec change over, it wouldnt be a bad idea to invest into a wideband so you know if U try to push the limit, ur not leaning out... somethin me and my friend have done to his aspirated Sentra 2.0; awesome tuning tool!
Old Dec 8, 2006 | 10:52 AM
ROCK's Avatar
Reading through what you really want to know, pistons are the weak link. Asking the question like you are is over simplifying the issue though. You have other things that will not allow more boost. I think we taked on the phone right? So far you need more of everything if you are going to boost more. Hope that makes sense.
ROAD/RACE
Old Dec 8, 2006 | 11:38 AM
readrs13's Avatar
the clutch
Old Dec 8, 2006 | 02:17 PM
mitsumivec's Avatar
ROAD/RACE
yup, we did talk on the phone.. by the way how much is installation for those forged pistons of yours? and are you guys ever going to develop rods like you did with your other lancer?
Old Dec 8, 2006 | 02:31 PM
captain150's Avatar
Originally Posted by readrs13
the clutch
Yep.
If we go away from the engine then he needs new tires too Actually, every RA needs new tires.
Old Dec 8, 2006 | 03:15 PM
MITVRX's Avatar
Correction, stock Advan Yokohamas here!
Old Dec 8, 2006 | 04:32 PM
chowetime's Avatar
The good thing here is that you know what sort of power that you are wanting annd were you are going to use all of this power... which means that you can go to your tuner with these numbers and then build the car to that level - the bigger the power output the more stressess that you put on the car and not just the engine internally either it will also relate to the suspenssion - engine mounts - gearbox - clutch flywheel - tires etc...
But everything comes at a cost more power equals more $$
