My car rolled off the jack
wow..you're lucky. i'm scared to jack my car now...eventhough i use the e brake and wheel chocks all the time...just the thought of the car falling on yah while you're under there is terrifying.
I'm scared everytime I'm under there, I spend quite a bit of time making sure I'm safe first. I don't want to be a stat !
That "almost" happened to a friend of mine while we were putting on his spare. Basically we have it off and was putting on the spare and some how the car rolled back. He had just put the wheel on with no lugs yet. Scared the **** outta me! Screwed on the lugs we could and jacked it back up.
When changing tires you should do all the above if you can.
When changing one on the side of the road set the e-brake and put the spare under the car while you take the flat off, and then put the flat under the car and put the spare on. That way if the car falls it won't fall to the ground. BTW, be careful with jackstands on asphalt when it's hot, they will sink in.
If you are going under the car it's ramps and chocks or jackstands, nothing less.
