wierd shifter feeling
Old Jan 12, 2007 | 09:26 PM
Edd's Avatar
Edd
my ra just barely has 4k miles and i dunno if its normal to hear a squeaky sound when i put it in first gear(it only happens there) and is it normal to feel a clunky hard feeling when going from 1st to 2nd gear
Old Jan 12, 2007 | 09:32 PM
jonpfive's Avatar
n/m
Old Jan 12, 2007 | 10:54 PM
captain150's Avatar
My shifter was making a squeaking noise so I took the center console out and put some grease in there. Didn't look like much was in there from the factory.
Old Jan 13, 2007 | 03:47 PM
blackhawkRA's Avatar
Yeah grease will help big time. Also, brass or polyurethane bushings will get rid of that "clunky hard" feeling and make shifting smoother and more refined. I recommend KartBoy polyurethane bushings, but I hear great things about brass as well. If you do install them, grease them up nicely to ensure full improvement.
Old Jan 13, 2007 | 03:57 PM
AdamRA's Avatar
I also recomend kartboy bushings (but they require monthly greasing at least on my car or they squeak) Have a look at how much your RPM drops when going from first to second thats what was causing my clunky feeling was just the way the gear ratios are and how I was driving and shifting from first to second(a little more rpm in first problem gone).
Old Jan 13, 2007 | 09:59 PM
Edd's Avatar
Edd
ty guys ill try all this stuff out ASAP
Old Jan 14, 2007 | 08:18 AM
Edd's Avatar
Edd
any procedures one should know so the center console dosent damge while taking it off?
Old Jan 14, 2007 | 08:47 AM
Myszkewicz's Avatar
Remove the rear console first. The front console doesn't have to come all the way apart, just have to be able to get under it and work on your shifter.
These should get you started:
Old Jan 14, 2007 | 12:35 PM
SlowRyd's Avatar
I have the brass bushings from lancershop.com. They made a HUGE difference. I highly recommend them.
Old Jan 14, 2007 | 06:14 PM
console instructions
underhood instructions
just be careful with the little plastic buttons. also be prepared to file the console bushings down if you go with poly.... if you wanna skip this step go with brass.
i also recommend that you do both underhood and console while you're at it. both make a big difference.
Old Jan 30, 2007 | 04:17 PM
Edd's Avatar
Edd
ok guys so is it normal that a stock shifter needs greasing so early(6month-ish) and in these days the car has not been responding like normal when shifting. i.e lauching from 1st and proper "feel" of the shifter when u make a gear change....is it me....is it the car....im a bit worried
PS: and yes the usual rpm change from 1st is 2500-2900 and 2500-2700 on city driving(getting till 4th and around 45-50mph)
Old Jan 30, 2007 | 10:35 PM
captain150's Avatar
Well, I had to grease my shifter after less than a year. I think it just wasn't greased enough from the factory. I piled it on though, should be good for another 20 years
Old Jan 31, 2007 | 05:59 AM
rdc's Avatar
rdc
If the clunking sound only happens during the 1-2 shift, remember our car has a clutch restrictor (makes it engage a little slower), so you might want to try making sure the clutch is fully engaged before shifting. (during the 1-2 shift is where you will notice it the most as the torque is multiplied the most and the engine will rock like a Van Halen concert )
emperor496
Mitsubishi TC-SST Discussion
21
Sep 19, 2019 12:28 PM
Simmons
Nov 2, 2013 08:46 AM
sonic_evox
May 12, 2011 12:25 AM
fr0nz
Lancer Tranny/Drivetrain Tech
21
Nov 22, 2007 04:11 AM
taylor
15
Feb 16, 2005 08:10 PM
