I dunno If its a big deal?
Well sometimes, well mostly of the time when I put my keys in the ignition and turned the key I guess to ON where the radio plays and everything works it does this TIK TIK TIK and stops.. WTF! you can her it, it comes from the engine
I always thought it was the ABS system calibrating itself or something. Injectors makes more sense though. The reason I thought it was ABS is this is the first car I have had with ABS, but not the first I have had with injectors. All my other cars made a humming noise(fuel pump) when you turn the key to ON. I had one car that you had to wait until the car was done checking itself out/pressurizing or it wouldn't start at all.
Otter's right, it's the fuel injectors. Listen under the hood of any fuel injected car BEFORE they turn the key the first time as it will not allways prime (not sure how it knows how much priming it needs, it just does) on subsequent turns unless you wait a little bit before turning again. It's the fuel injected version of pumping the pedal a little on a carb motor.
We have a winner!
