fog light assembly
Old Mar 13, 2007 | 10:27 AM
Ralli04's Avatar
fog light assembly
i searched but couldnt find it...i know some one on here has a picture/spec sheet of the fog light assembly cause i need to replace one of the bulbs that went out. if im not mistaken i believe it was otter that had it? or one of the mods...
Old Mar 13, 2007 | 10:37 AM
bruce988jl's Avatar
Otter has it, i have it at home but i won't be home till late. Basically its 3 small philips screws that around abotu an inch and a half long on the underside of the assembly. Un-screw those, take the plate their holding off (the plate will hang as it it attached to the assembly because it holds the wire that the bulb attaches to). Undo the metal spring active device holding the fog light in place and carefully pull it out. When installing becareful with putting the bulb in, it takes a couple of times to figure out how to get the bulb in, so look at it and note its positioning before you remove it. That or practice with the old one. Also the connector for the wiring is a pain to click back together thanks to that rubber umbrella protecting the metal from water. Seat the light bulb in place, push the spring-loaded device (honestly don't know what to call it) back in place and make sure the wire isn't sticking out when you're putting the cover to the assembly back on. Be careful as not to strip the screws at you put them back in, or loose them.
I hope that helps.. i'm sure the spec will be posted by tonight if not i'll toss one up.
Old Mar 13, 2007 | 11:15 AM
Achilles's Avatar
+1 on the screws. Be careful with the screws because they strip pretty easy.
Old Mar 13, 2007 | 11:51 AM
Ralli04's Avatar
i had the fog lights replaced when i first got the car with a set of silverstars and the guy told me the screws were already striped...not the threads but the heads were pretty stripped...any suggestions when i get there?
Old Mar 13, 2007 | 12:16 PM
superalf574's Avatar
go to a auto parts store and buy new screws
Old Mar 13, 2007 | 04:55 PM
lanzerralliart's Avatar
EvoM Super Moderator
get stainless steel , because regular will just rust out and you'll be back where you started...
Old Mar 13, 2007 | 08:05 PM
CF-Ninja's Avatar
Those screws absolutely sucked! I striped them and I was using a screw driver that was exactly the right size. Try and find replacements.
Old Mar 13, 2007 | 08:12 PM
bruce988jl's Avatar
yep, i'm working on finding new ones as well. I might have to order them specially through my work. If i find them i'll post up some info, but first i have to take the screw out first...
Old Mar 14, 2007 | 02:48 PM
Ralli04's Avatar
still could use a pick of the assembly if anyone has one
Simmons
Feb 25, 2017 04:11 PM
chrisoneil4
Apr 7, 2015 07:00 AM
punk3r
Evo X How Tos / Installations
May 14, 2013 08:21 AM
norcalrep707
Lancer How Tos / Installations
Nov 25, 2011 09:39 AM
GsrEviluTionX
Dec 30, 2010 07:55 AM
