Kit NOs
Old May 9, 2007 | 07:39 AM
Ralliart_on_LSD's Avatar
haha only 13s ... working on the magic 12... give it time it was my first time at the track... i will be hitting 12's by summer, posting videos and slips
Old May 9, 2007 | 01:02 PM
superalf574's Avatar
Originally Posted by PR_Mivec
cryo cant go into the engine....so you wont benefit from it at all.. the only thing you can use it for NA is to spray the intake manifold and even more whats the benefit NA 'wise'? rather than spraying the manifold you are better off with phenolics in that department... (cooling)
and as for nos 50 is safe IF INSTALLED CORRECT and even correctly you could damage it if for example you redline the engine with the system on.. for that reason yes buy a kit and buy a window switch.
to lsd:
only 13's???
i have seen a cryo2 na rsx with it engaged gained 35hp with only intake and exhaust . yes i understand it doenst go directly into the enigne it cools down your intake i.e better combustion when you have your car on a colder day more dense air . also im ordering a cryo2 kit in the summer . just my two cents
Old May 9, 2007 | 03:27 PM
PR_Mivec's Avatar
and i respect your point of view
