Wheel width problem
Old May 19, 2007 | 08:44 PM
SiRiUS's Avatar
Originally Posted by lanzerralliart
......man I hope SiRuS is reading this , he also got 18s.......good luck to the both of you ......
hehe! my offset is 42mm though. and the tires are 215/35.
I wonder what barnsey's tires are. they are likey a 225, 235, or more. (and since he said his diameter is the same is likely on 35 profile tires)
18x8's are much too wide! 7.5 width is cutting it.
I got 18x7 to be safe!!! (most people run 17x7 on their Ralliarts with a higher profile tire and have no probs) I spent hours and hours on forums and talking to different shops. The combo I got will fit with no rubbing.
Our wheels arrive Tues or Weds. Will post our results.
Old May 19, 2007 | 09:14 PM
SiRiUS's Avatar
Originally Posted by BARNSEY
When i purchased the rims, we put in the computer my year and model, and i got the fitment size it said. Since the rims were on sale, they were a final sale...because i really didnt think a program designed for the sole purpose of sizing cars would be wrong.
What is the correct size?
This shop sounds like it has horrible service. If they were the ones that suggested the tires and installed them, and they turn out not to fit, they should take them back regardless. (now i'm curious what shop you talked to)
Old May 20, 2007 | 02:42 PM
Smartie's Avatar
x2 ! Take them back, they told you that they would fit, and they didn't fit. Yeah, what shop is this?
Old May 20, 2007 | 06:38 PM
profkirby's Avatar
I agree with SiRiUS, 7.5" width is a push and then probably only with an offset
of 45mm or real close and 225 width is probably the widest to safely use without modification. Your wheels are two inches wider than stock and even at stock width your offset still makes your wheels stick out 10mm more.
Return them or trade them for something that fits.
Old May 20, 2007 | 08:15 PM
bruce988jl's Avatar
Yea i went with 7.5 and that was cutting it...
Old May 24, 2007 | 09:51 AM
GearDownSon's Avatar
See my thread
Hope this helps...
https://www.evolutionm.net/forums/sh...05#post4363805
