radio and clock stopped working
Old Jun 7, 2007 | 01:53 AM
ralli_DC's Avatar
I did search for this problem maybe I didn't search the right words but anyways..........
The other day I was cleaning out the car and listening to the radio and all of a sudden the stereo went out. I looked in the engine compartment fuse box and I did end up blowing the fuse. I changed it and still have nothing. The clock stopped working too. The cigarette lighter still works just the stereo and clock anyone help me out on this?
Old Jun 7, 2007 | 04:06 AM
drewbad's Avatar
Curious--does your curteousy lamp (on the ceiling) work? If not, it's the fuse in the engine compartment. One of the two in the small yellow retainer. It's tricky to get out, probably because it has to do with the airbag circuitry, I'm not sure. The two fuses will pull out as an assebly in a mall bracket. Then you can test each fuse. Let me know what you find.
Old Jun 7, 2007 | 04:17 AM
ralli_DC's Avatar
yeah it is when i saw that i blew the fuse i took the dome light fuse and put it in where the radio one is and the radio still wouldn't work. Did find out that if the dome light fuse is out the doors won't lock from the key lock. which is kinda cool. I will check back later work nights so really sleepy
Old Jun 7, 2007 | 04:57 AM
DangerousDan's Avatar
there is a fuse box behind your change door, under the steering wheel. have you checked there yet?
Old Jun 7, 2007 | 06:27 AM
bruce988jl's Avatar
I think that's the first one he checked (refering to Dan).
Old Jun 7, 2007 | 12:36 PM
ralli_DC's Avatar
yeah checked there the radio fuse is in the engine compartment
Old Jun 7, 2007 | 03:05 PM
there are lot's of fuses, more than one control the radio IIRC.
Old Jun 8, 2007 | 09:20 AM
ralli_DC's Avatar
Hey thanks y'all for helpin i looked for all different fuses and i just think i blew the hell outta my radio. Appreciate it.
Old Jun 8, 2007 | 09:50 AM
and the clock? seems unlikely, possible though. test to see if you are getting power to your constant and switched lines.
Old Jun 8, 2007 | 09:56 AM
Cj98's Avatar
Um you need to pull these fuses out in the yellow
same thing happened to me..just go to napa or somewhere and get some small 10a's
Old Jun 8, 2007 | 11:05 AM
+1 that yellow thing sucks nuts
Old Jun 8, 2007 | 11:16 AM
ralli_DC's Avatar
yeah that damn yellow thing does suck. I have switched those 2 fuses out and i am going to try the constant and switch lines. Sweet thanks y'all
Cody Parrott
Lancer Troubleshooting
Jul 10, 2024 08:41 AM
Charlie-Y
22
May 4, 2022 03:56 AM
Drooke
Sep 10, 2008 09:35 PM
BornSinner
Nov 1, 2007 09:27 AM
Evoisdream
Jul 29, 2005 07:30 PM
