Tool-less oil changes?
Old Jun 11, 2007 | 01:37 PM
EvoSid's Avatar
Originally Posted by cfdfireman1
Is it that hard to loosen and then tighten one fastener?
You're never going to know unless you've used it but it does simplify the oil change even more.
Old Jun 11, 2007 | 09:08 PM
Myszkewicz's Avatar
Originally Posted by bruce988jl
Myz, you ever have problems with it gunking up and such?
No such problems, even when driving through snow several inches deeper than my ground clearance. The angle of the plug in the oilpan shields it pretty well against this kind of thing, and anyone who tells you it might accidentally open has never had one. You have to lift up on a spring-loaded lever, and then turn it to open the valve. It is pretty difficult to turn, you have to really want to open it.
Mine has never leaked, opened accidentally, or gunked up to the point where I couldn't open it when I wanted to.
Old Jun 11, 2007 | 09:22 PM
AdamRA's Avatar
Is it that hard to loosen and then tighten one fastener? Never mind I've seen your track record.
The oil drain bolt wears out faster than a fat man in a marathon.
It is really nice to just put your hand under and flip the tiny little valve handle
Old Jun 11, 2007 | 09:36 PM
Joho22's Avatar
+1 to evom
ordering on friday!
I <3 evom
Old Jun 12, 2007 | 10:08 AM
cfdfireman1's Avatar
It's all good till you dump all your oil on the street or track somewhere.
Old Jun 12, 2007 | 10:10 AM
DangerousDan's Avatar
I can see that happening, is there a pin or locking mechanism on any of these valves?
glgz's Avatar
^^^That would be my fear as well.
Old Jun 12, 2007 | 10:13 AM
Joho22's Avatar
who smells a part out if i do leak that stuff?
Old Jun 12, 2007 | 06:04 PM
bruce988jl's Avatar
I read up on a bunch of other local forums about them, and no one has had problems with them. They've even run some on off road trucks and they worked fine.
Old Jun 12, 2007 | 06:10 PM
AdamRA's Avatar
The Japanese cars are coming with these stock.
The valve handle which is hardly over 1 cm drops in and locks. You would have to bottom out to the point that you crush the oil pan by then it's alreadyt to late and the dmage would be done to the pan anyway.
Old Jun 13, 2007 | 03:45 AM
thanks adam, I was waiting for someone to use the word "locks" in some fashion. I don't mind unscrewing the plug, except it's super mess. Do you remember the threads for the plug by any chance?
Old Jun 13, 2007 | 05:59 AM
Joho22's Avatar
gonna need that info too,
cause im too lazy to check,
just like dan.
Old Jun 13, 2007 | 06:23 AM
Dan's at work man, but yeah I probably wouldn't look at home either
Old Jun 13, 2007 | 06:25 AM
Joho22's Avatar
thats two of us at work
Old Jun 13, 2007 | 09:22 AM
bruce988jl's Avatar
the model number was included in my post on the first page, i bought mine from fumotovalves.com
