Intake Manifold > me
hmmm....sorry bro you have to get under her, it will be a lot easyer to do this way, o-yeah and if you plan on doing the motor mounts that would be the best time with the IM outta the way....
Yeah that rear mount with everything in the car can be a pain, but its still not "hard" requires a little more patience in getting it done, and i'd HIGHLY recommend ratching box wrench, such a huge time saver,
hehehe, ok true, but truth be told, when me and a friend did the mounts on my car, there was no cussing involved (atleast that i can remember), creativity however was oozing out of every corner of the engine bay to get that rear mount out
Yeah we used every combination of universal and extension and short or deep socket I had to finally take that thing off. Hopefully it'll go on much easier now that 1) I know what to expect 2) some of the bolts wont be seized up and 3) I have friends w/ smaller hands who can help from the start lol
Interesting, cus i only used one short extension, and that was it, no u-joints what so ever, but i did most of the removal and install from under the car with the center member removed. like i said thou, the ratchet box wrench saved my life on this one lo
my ratchet box wrenches are too wide for most things that I have needed them for. that's what i get for buying harbor freight
who makes the ones that aren't ratchet but slip in one direction? you flip them over to tighten or loosen? I need some of those.
That thing is damn near impossible to remove. Theres so many bolts in the most ridiculous of places and you need the hands of a 3 year old to reach in to put a socket on them. I have never had a more problematic time with taking a part off
Up until now I thought the bolts "underneathe" that I saw posts about people have trouble reaching were the ones on the lower part between the runners, little did I know mitsubishi bolted this thing down to every spot they could find. Also, I more or less painted my garage floor with coolant.... What a PITA
I thought of Bob Villa when you mentioned those wrenches, so it's probably Craftsman. That's not a bad idea, either. My ratcheting box wrenches are a bit on the fat side, too.
http://cgi.ebay.com/ebaymotors/gear-...32160692QQrdZ1
yea the IM is a real PITA...most troublesome thing is the bolts under the IM and for taking it out you will need help
....as otter said o-ring might break or stretch. After installing look carefully at the Temp gauge...most likely engine will get hot becuase air got in the cooling system...this happened when isntalling on qlitv's RA
solution was wierd but.....it worked
unhook one of the hoses of coolant that goes to the TB(not the return one)... open the lid of the coolant PLASTIC container, put your mouth there and blow away until coolant comes out of the hose....
....as otter said o-ring might break or stretch. After installing look carefully at the Temp gauge...most likely engine will get hot becuase air got in the cooling system...this happened when isntalling on qlitv's RAsolution was wierd but.....it worked
