Engine misfiring?
Old Oct 4, 2007 | 07:09 PM
AustinG's Avatar
Engine misfiring?
While holding a constant speed and constant RPM, I feel a slight misfire or slight bucking. It's difficult to determine whether it's my imagination, bumps in the road, or if the engine isn't running smoothly. My car has almost 50k miles and I have not had the HLA's adjusted .
Does what I describe make sense to anyone? I'm planning to do the valves this weekend, maybe that will take care of this?
Any help is much appreciated.
Old Oct 4, 2007 | 09:39 PM
06RedRalli's Avatar
My car does this too I am as well stumped why it does this my ralliart only has 22k though...
Old Oct 5, 2007 | 06:38 AM
bruce988jl's Avatar
try running some injector cleaner, not sure why i did that when mine sputtered a bit but it fixed it.. that or it did something at least. I just bought some lucas stuff from Autozone. I use it every 5 tanks.
Old Oct 5, 2007 | 07:06 AM
otter's Avatar
EvoM Administrator
I just troubleshooted this in my car a couple months ago. It ended up being the pedal position sensor (the speed control thing behind the headlight.) It seems that the connection doesn't always stay tight, or something like that. I haven't replaced mine, but a few times I've unplugged and replugged it and the issue went away for awhile. If it only happens at a constant speed, chances are that's your culprit.
Old Oct 5, 2007 | 08:40 AM
06RedRalli's Avatar
and where is this culprit located pics would be great... or what does it look like/???
Old Oct 5, 2007 | 09:11 AM
AustinG's Avatar
More info on where this is?
Old Oct 5, 2007 | 09:25 AM
otter's Avatar
EvoM Administrator
It's the throttle control behind the passenger headlight, right next to the washer fluid. It's impossible to miss; it's where the throttle cable goes.
Old Oct 5, 2007 | 10:00 AM
06RedRalli's Avatar
ok ya ive done that before just unplugging it and then back in but still got the prob...maybe this will help the other guy...mine still does it so im lost...
Old Oct 5, 2007 | 03:25 PM
otter's Avatar
EvoM Administrator
Chances are it needs to be replaced, but it's not a cheap part. Since you have an 06 I'm sure you have your warranty still. Let the dealer deal with it.
Old Oct 5, 2007 | 05:57 PM
Rallilanc's Avatar
i replaced mine, but the problem still occurs and no one can figure out why
Old Oct 5, 2007 | 06:04 PM
KreepaEvoX's Avatar
If your Service Engine Soon light is lit, most likely the car is reading a fault with the O2 sensor. mine was doing it BECAUSE I INSTALLED A A/F METER... dont know why but if you intercept the signal.. a random misfire code gets thrown in and the car bucks.... How did I solve it? reset the Ecu and ran stock configuration for a while... never had the code again
But U get a random misfire event if you have that throttle cable thingy unadjusted as well
Old Oct 5, 2007 | 06:51 PM
Rallilanc's Avatar
so are you saying i should disconnect my a/f meter??????
Old Oct 5, 2007 | 07:20 PM
KreepaEvoX's Avatar
LOL, I kinda knew it
yes, disconnect that *****...for some reason, it gives u issues
Anyboy else experiening this, or somebody with a fix to that little bug?
Old Oct 6, 2007 | 07:15 AM
Rallilanc's Avatar
when you had your a/f meter in did the problem start right away??? i had mine in for about 6 months before it started.
Old Oct 7, 2007 | 03:52 PM
KreepaEvoX's Avatar
it kinda has to do with it... mine did start a couple of days after...but @ that time, I raced my car a lot
Took me like 6 races in a ROW for it to start....and they were not 1/4 mile ones either..... TOP SPEED SRS races at them
I left that night with my car limping and bucking until the next day that I came from work. I reset the ECU, took the meter off, downpipe off, intake off and I was gonna take it to the dealership the next day, but after reseting it went away.
P.S> Has to do with the sensor, something about the voltage it uses, if it ever goes down enough, it gives a blurry reading and the ECU craps itself... to this day I havent installeed the A/F again...... thinking about a wide band or a Pyrometer
